Crispyeel's 5E-FTE Forged Build
Well I've been a member on here for a few months now but finally became the proud owner of a late 99 Glanza V yesterday. Thought I'd start my build thread straight away since I have quite a bit planned for the car Here is my Glanza V. Had to trailer The car to my house since its a fresh import, not even registered yet & never seen the Scottish rain fef89250233bbd5015f0b9e7360724f3.jpg5cb8c2042b2014d147832ec1e10537af.jpgf026d8c45b043a7a4d46832d17a6c600.jpgdc028a7b1d4b6e3fb4e6006949706c5d.jpg2c237e4230b342f4e670659043dbf1c6.jpge41daabca13be535e59625f3820de434.jpg
Edited by crispyeel
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Today was the first of many more days of hard work. Myself and a friend began to strip down the car in preparation for the first modification, the HDI front mount intercooler.
All of the intake, standard intercooler and air con system have been removed so far
Edited by crispyeel
Small update. More parts arrived this week
Non air con belt, New roof gutter mouldings, spare key & touch up paint
Timing belt kit, water pump & air filter relocation kit. All from ID Workz
Posted Image
Also purchased a Japspeed cat back system from 'Matt' a member on this forum
Posted Image
Posted Image
Just waiting for this horrible rain to stop so that I can get cracking on with fitting some more parts :lol:
Today was a good day for progress
Shorter alternator belt fitted and the car now runs again :D
New Kenwood stereo fitted and working. Wiring was a bit if a mess behind the old jap double din stereo
Posted Image
Rather than mess about cutting and joining wires etc I purchased a simple plug & play loom from eBay. Much neater
Posted Image
Also fitted the new pillar pod and two gauges. Boost and oil temperature
Posted Image
  • 1 month later...
Not been on the forum much lately but there has been some good progress made with the car.
Now all fully UK registered, taxed & insured HDI intercooler fitted, air filter relocation, blitz bov and the Japspeed cat back
Still got some tidying up to do under the bonnet but this will be done while the car is garaged over winter Within the first 24 hours of the car being on the road I under sealed the car at my work. I have since put another coat on last weekend but I could not believe how clean the car was underneath. Hopefully I can keep her that way!
4d8a30cb2b5c423757f99e4973655360.jpg2458012f9516698b511f3a36fd6621d2.jpgae470ffe63088ad9ea0981e706819705.jpg7fb8f53aee3786741d2785577c22802a.jpgb876f33c773f931ab10748e659db2287.jpg5a26dc2cb3a983154886c28cc2299f51.jpg
Edited by crispyeel
  • 3 months later...
Well its been a while since I last updated this thread. Few changes have been made and still got a lot more planned :D
The car drives ok just now but suffers from the common and dreaded boost creep and hits boost cut regularly due to this. Something needed to be done :p
With some of the plans that I have, the car will require a remap. Managed to secure a Greddy Emanage for a good price
Posted Image
Also managed to cut a deal with a friend on an upgraded turbo, exhaust & tial external wastgate
Posted Image
Posted Image
Finally got some time yesterday to set about removing the old turbo & manifold setup. Was surprisingly easy considering that I am not a mechanic by trade. Only issue that I came across was that I had to split the turbo off the manifold to get to the lower manifold nuts
Posted Image
New setup was already to fit as it was removed from a Glanza. New manifold gasket fitted and braded coolant lines fitted
Posted Image
Posted Image
Almost good to go but just need to get my hands on a new pipe for the air filter relocation as the CT12 is obviously larger. Also need a new oil return pipe as the old CT9 one is too short. Also need a smaller radiator as the hot pipe sits hard against the standard radiator
Been very much trial and error with this car and I have loved every minute of working on it so far and looking forward to getting it running with the new turbo setup very soon!
  • 2 months later...
Been a while since I updated this thread. Quite a bit has changed since the last update
Purchased a Greddy Profec boost controller so that I could safely control the boost for and after the mapping
Also purchased some new blue silicone hoses to fit to the new radiator
Radiator was a complete sod! Fitted perfectly apart from the bottom radiator hose fouling against the screamer pipe :unknw:
Decided to take the radiator back out and send it to a local welder to have the bottom outlet cut and moved over approx 4" to allow clearance of the screamer. Got the radiator back less that 48 hours before my 4 hour journey down to Tuning Developments for my E-manage mapping session
Thankfully the radiator was perfect. Re-fitted, filled and bled before taking the car for a short run to double check for any leaks. All was good
Edited by crispyeel
