Content Count
8788 -
Joined
Last visited
Content Type
Profiles
Forums
Wiki
Media Demo
Store
Calendar
Everything posted by morgey
Can tell i dont get on here much these days haha. Think i had been up the coast and was heading to kfc lol. Im not normally out that way, more wymondham area, but if you ever see me feel free to introduce yourself 👍
Nice to hear its nothing major! Always a bit of a worry when something like that happens lol
- 343 replies
- Slowest project ever
- Bluebear
(and 1 more)
Tagged with:
Any nice big spec starlets bein built lately
morgey replied to AlancEP82's topic in Lifestyle General
These things take time, no point in rushing it. Will be worth it though! -
Nice work on the upgrade, looks a good workshop 👍
That is some build, can't wait to see it out on track! Good to see people pushing the boundaries of these things still. -
Was showing a fella at work this earlier, think he was surprised by how much power its currently making so will be good to see what it can do after your handy work!
Awesome swap, looks nice and tidy too does it sit low or is it not too bad? Any idea what the short master cylinder is from? I could do with something like that on mine to clear the airbox. Not that you need it with a standalone with safetys built in but you should be able to get the temp gauge working with a 4efe temp sensor plumbed in somewhere. Cracking motor mate look forward to seeing more from it!
Cant help on measurements im afraid but can give you a heads up. If the seats feel like they are really high i would opt for some low rails, i had OEM rails on my seats and felt like driving a bus. I was then informed of a guy in Ireland called William Tuite, can find him on Facebook, who makes low rails for 6 bolt recaros (most oem fit recaros). They're about £230 delivered a pair to England and sit a couple of inches lower and give a much better seating position, they slide as well. They might be a over what your were going to spend but imo they are worth it.
I would go for alk and coilovers first. If you dont go silly with ride height you can get the geo setup done and play around with wheels later and it wont effect it. It might be worth throwing new ball joints, track rods and wishbone bushes on there at the same time if you dont know when they were last done as you will need the geo doing again any time these are replaced.
its there, on the flat between the hinges. Below the check strap, you'll need to get your fingers in there to feel for it.
They look like them, there might be a control box and a relay need too, that go under the dash but im not sure where, someone breaking a car might be able to advise. as for the hole is there not a rubber bung behind the door shuts?
Im a 30yo in a jap ricebox i dont need to advertise that fact by shouting from the rooftops haha. I prefer to be Subtle and blend in, then catch people off guard
Its an extra silencer to shut the bloody droning up
Got a new o2 sensor to see if it fixes the over fuelling issue, can fit my cat then and we're all legal Couple of other bits enroute from japan, new manifold gasket, and iacv to inlet pipe, hoping it brings my cold idle down. Going to whip the idle valve off and clean it whilst im at it as the revs hold occasionally.
In some cases they are, pull the kick panel trim off and see if theres blank plugs down there.
What model is it for? If ep8* or 91 then just get the genuine bits and door cards, sometimes you'll have the wiring to just plug into otherwise you will need to make your own loom. Its fairly self contained so only needs wires going between drivers and passengers switches then a power and ground to the drivers switch.
Its my daily atm, the corolla is half broken lol
Likewise mate, was good to see some other Sr's about and fair play to you, yours is so clean maybe next time ill make an effort and get mine scrubbed up so it looks half as good as yours haha
Looking good mate, i need to give mine a thorough clean its fucking minging and the weather is not looking good before JF
Yeah it does, works a small rotary valve, can get choked up with oil vapor due to its location on the inlet but its easy to clean out.
Help identifying a diff - is it an lsd?
morgey replied to Farley V's topic in Drivetrain & Transmission
Thats a standard open diff mate -
Yep, if its not on the shelf just let them know your paint code and they can mix it up
From time to time, i dont use it much as everytime i do something else seems to break, like tonight for instance, went to the pub and now my osf brake is making a weird noise like a piston is seized or something..
