Content Count
1047 -
About DRiiFTiE
Rank
Boosting a Starlet
- Birthday 02/16/1996
Birmingham
6043 profile views
Glanza. Not getting reading from the front passenger ABS sensor. WANTED ABS SENSOR
Glanza V 1998 I think I have ABS problem, need some opinions! Undone nipples can’t get no fluid through.. The same both sides. Peddle Stays hard to press. Bypassed rubber hoses but still the same and with engine running still the same.. im thinking it’s an ABS Issue? would be much appreciated to get you’re opinions! Cheers
Bought a OEM Fuel Reg & Lines. Turned up next day. Can’t get better than that. A* Seller
If you change the manifold I will take original off you.
Ring or cracked piston
I got a emanage blue £170 with map sensor and harness
4efte Air filter relocation kit(sold)
DRiiFTiE replied to RoyalDutchie's topic in Starlet Parts For Sale
I’ll take it PM me please. If you can do a little less? Just found both items for £23 delivered new on eBay -
DRiiFTiE started following RoyalDutchie
Still here I’ll take? -
any seats or even standard seats? upto 50
Is that the code for Toyota? Synchro 5?
If you dont mind about color.. I have a Lilac/purple sort of one, just hit 80k miles have paperwork for cambelt,water pump, clutch. has had brand new rear shocks and fronts replaced. starts and drives perfect. currently using it as a daily. £650
wheres he located
