MR-2
  • Content Count
    762
About MR-2
  • Rank
    Boosting a Starlet
    Finland
    Toyota
2447 profile views
  1. Used to look like this earlier, K-Sport coilovers, Sparco seats, Windows tinting, turbo hood and grille, tooked all away to get more sleeper look. Color is mk1 Yaris, used to be light gold earlier. Bought it little project, engine didn't work well and boosting only 0.2bar, solved problem and it was jammed wastegate and some leaking Weber DAT 32 carburator, now working well again, but wanted to restaurate motor better. Building car with my 17years old son, will be his first car, baybe likes or then not when seeing other kids new cars 😅
  2. I have had this car on storage place several years, last autumn I took it to building garage back, plan was make it good again, made few cosmetic tricks to fool some drivers, it used to be more 90's/00's time tuning car and also builded that time to carburator 2E turbo, gona keep it that way, some old school 🤐
  3. Here few outdoor Last summer pictures from canvas top EP71 and some friends cars also.
  4. I also bought few more EP71, so my "granny" project had to wait on storage place, wanted to do this light silver first, then granny, but now started to build yellow one after few years. I have done other projects also, so Starlets takes time. Silver one changed color to Toyota oxide bronze, silver was too boring.
  5. Thanks. Started to weld few holes, then found me doing everything, too typical for me
  6. My dailys EP91 and latest creation EP70, with 2E-E engine and canvas top, tooked about 1year and 1000hours to make, now engine is under contruction and service.
  7. It has been long time when I was here last time, several years. "Granny" is still waiting her turn to be turboed. I have taken few other boxy Starlet projects and have bought/sell few newer ones, sick destiny 😕 Now working on my canvastop EP71 2E-E engine and bodywork to my EP71 carburator 2E turbo with my son to his first car next spring 2022 when hes coming 18years driving age.
  8. I have same problem here, can´t renew my membership, my account needs also resetting. MR-2
  9. There might be wrong drivesaft, I just changed to my "new" EP70 Starlet drivesaft, old Corolla was popping out same way, it is too short. Previous owner had changed wheelhubs from EE90 Corolla and that why used bigger bore outer joint drivesaft, fail.
  10. Thanks for info, I still have my 1E engine mounts, have to try that for 5E block.
  11. Sad that Photobucket killed my picture links, nothing bigger haven't happened. Engine/transmission is out and some parts are taken out, gona clean all out and then body goes maybe sand blasting while I restoring all other parts. Just made blower plate for my modded radiator and one pipe is moved and few mounting treads are welded on to the top, so slow project, too many other projects going on at same time :/
  12. Speaking myself, sorry :/ Drivesaft comparsion EP70 vs GT EP82, same lenght, right is only little thicker and outer joint treads are bigger, but fits to EP70 hub.
  13. Starlet parts should be almost identical, I have Starlets and Paseo EL54. I have mixed some parts to older EP70 from newer models, so those are also one choice. Droplinks are two version, You have check those visually first, front bushings have also two size, rears are same, and so on... EP70 arms and EP91 arb pictures for example
  14. Wanna recomends about KP60 to EP91, how about basics first, engine and horsepower. Normally oem disk and maybe just better pads...
  15. You need this kind of lug nuts, can find Your local dealer or ebay for example.
