Content Count
37 -
There was a brown and white wire that wasn't pushed fully in on the smallest plug in the middle of the clock. I fixed that and it has fixed the problem. Thanks
OK thanks. Il check the wiring again.
Hi, I have recently installed the CD dials to the Sportif. I changed a few wires around as per a guide on here. All lights showing in the correct places and rev counter working. However, when I put on full beams and drive somewhat harder, 30 - 40mph, the fog light and indicator lights illuminate dimly. When I indicate on full beams, both indicator lights come on as well as the fog light. This issue only happens on full beam, dips are fine. Any ideas what it could be that's causing this? Maybe a loose or crossed wire maybe? Thanks
Hi, I've blown the 100A fuse for the alternator on my 97 Starlet. I am just wondering would anyone have a spare one? thanks
Is anyone selling / or know of someone who is selling the full fishnet recaro interior for a starlet / Glanza 96 - 99?
grand, cheers for that info.
What I mean is the plastic bump strips yes. Theres a red sticker on each on mine. Id like to remove the sticker and the plastic bump strips too. Does it leave it so that I would have to be filled and painted afterwards or does it leave it the same as the way the Glanza is normally?
I have a question about the exterior of my car. It's a 97 Red Starlet Sportif 3 door. My question is: Can the outside of each door that contains the plastic panel with the sticker like this one: https://www.google.ie/search?q=starlet+97+red&safe=active&rlz=1C1GGRV_enIE751IE751&tbm=isch&source=lnt&tbs=isz:l&sa=X&ved=0ahUKEwjl6fyQvYPbAhVLCcAKHSN1CZYQpwUIIA&biw=1366&bih=637&dpr=1#imgrc=8nZQe9woUrUtkM: be removed from the car with a heat gun? Does it leave a big divot in the side of the car once its removed which would
Sorry for late reply, I dont have a tacho wire (the brown one) in my car. I did put the clocks in and everything works but it will not register the rev counter at all. So what do I have to do to get the rev counter to work? My Starlet is 1997 Sportif
I have received a set of Starlet GLS dials today and I was wondering is this wiring guide from an N/A to an SR the same as wiring GLS clocks into an N/A? http://www.ukstarletowners.com/topic/65688-clock-conversion-starlet-na-to-starlet-sr-cluster/
I was just wondering if anybody has the part number to the P29 cluster that is found in the GLS/CD Starlet? I have posted in the part numbers section but nobody has responded to the post. Finding it difficult to get the part number for it. These Clocks: ==>> https://i.ebayimg.com/00/s/MzJYMzI=/z/OLgAAOSwOEZZgv2T/$_86.JPG
I need to find out the part number for the Speedo clocks for a Starlet CD if anyone has it. This is the clocks with the Rev counter such as this one: https://www.google.ie/search?q=starlet+CD+p29&rlz=1C1GGRV_enIE751IE751&tbm=isch&source=iu&ictx=1&fir=iBjg1l2bbPRYoM%253A%252CQ7ndOuHbA1l9AM%252C_&usg=__vKaK5R248J7GDbllyroGL7p1xro%3D&sa=X&ved=0ahUKEwjduavXwfDXAhWHDcAKHWGVDxYQ9QEIKzAA#imgrc=kyco4AltERSivM: Cheers.
Ive been reading this guide: http://www.ukstarletowners.com/topic/8006-how-2-fit-paseo-clocks-into-a-starlet/?hl=%2Bpaseo+%2Bclock. This guy has a brown tacho wire. I don't have one in mine so i am not sure if following this tutorial will produce the same result for myself.
- 4 replies
- tachometer
- electronics
(and 1 more)
Tagged with:
I have a 97 Starlet Sportif 1.3i but I do not have a rev counter in my cluster. It just has Fuel, Temperature and the Speedometer faces. I have also recently bought a cluster from a Paseo which has a rev counter on it but I do not have a tacho wire in my car. How do I fit the tacho wire into my car before I install the clocks? My engine is 4EFE.
- 4 replies
- tachometer
- electronics
(and 1 more)
Tagged with:
I have just purchased new ball joints for my 97 starlet 1.3i sportif, do these need to be greased before fitting or do they come pre-greased? cheers Daniel
