Neep91 Posted April 28, 2016 Share Posted April 28, 2016 Swapped a standard Ct9 turbo to a Hybrid with external wastegate, car sounds like its running healthy. turbo seems to be spooling up fine but only getting about 0.1bar on the boost gauge and the car doesnt really go over 40mph. I haven't got any engine management on at the moment (not actually running the car just took it a short run) Any ideas why the car wont get more speed and lack of boost??? Quote Link to post Share on other sites
akyakapotter Posted April 28, 2016 Share Posted April 28, 2016 Do you have the fire ring in the external wastegate and the internal wastegae on the turbo welded shut. all intercooler pipes on and none blown off and waste gate vac lines plumbed up properly ? Quote Link to post Share on other sites
Neep91 Posted April 28, 2016 Author Share Posted April 28, 2016 Fire ring not sure on as haven't had it apart, internal wastegate penny welded shut and all intercooler pipes are definitely on and i have the top vac line on external wastegate venting to atmosphere and bottom one to the turbo Quote Link to post Share on other sites
StuDoc 72 Posted April 29, 2016 Share Posted April 29, 2016 Vac pipes dont really matter just now as they only cause the w/g to open, they would only be an issue if you were making too much boost. First of all, is the turbo itself healthy? Is the turbine and compressor wheels both undamaged? Secondly when you start the car and rev it at the throttle body with your hand can you hear the turbo spooling and making boost? If yes to all of those then..... Its looking almost certain like you have a boost leak somewhere though. Did you make sure to refit your mani gaskets and the hot pipe gasket? If you did then theres a pretty good chance you have a loose connection somewhere on your boost pipes where pressure is escaping. Quote Link to post Share on other sites
5e colin Posted April 29, 2016 Share Posted April 29, 2016 Do you have the fire ring in the external wastegate and the internal wastegae on the turbo welded shut. all intercooler pipes on and none blown off and waste gate vac lines plumbed up properly ? x2 the fire ring Quote Link to post Share on other sites
adzy Posted April 29, 2016 Share Posted April 29, 2016 If you put your hand under the screamer at idle can you feel fumes?Also what kind of wastegate is it? I had similar issues when I fitted mine, would only make 0.3 bar. Turned out to be the wastegate spring, even tho I bought a .7 one. Those eBay wastegate springs are dung.Could also try a bleed valve and see if it improves any Quote Link to post Share on other sites
MR-2 Posted April 29, 2016 Share Posted April 29, 2016 Tial copy wastegates are very often shit, my friend purhaced six Tial 38mm copys and one was holding boost. He is testing antilag systems and price was so cheap and not so important parts if copy fails. For wastegate never copy, unless you have deep pockets... Quote Link to post Share on other sites
MR-2 Posted April 29, 2016 Share Posted April 29, 2016 Which one is copy, couldn't see it nothing difference when comparing both in my hands. Very good copy, problem is inside. If you have use one of these, you may have problem here, take a google search :/ Quote Link to post Share on other sites
StuDoc 72 Posted April 29, 2016 Share Posted April 29, 2016 Blue one the copy? Quote Link to post Share on other sites
MR-2 Posted April 29, 2016 Share Posted April 29, 2016 Blue one the copy? Yes. Red is real 42mm Tial, amazing copy that blue, chinese are very good Quote Link to post Share on other sites
Bug679 Posted April 29, 2016 Share Posted April 29, 2016 Check the serial numbers that will tell which is fake http://www.tialsport.com/index.php/authenticity/117-sct Quote Link to post Share on other sites
MR-2 Posted April 29, 2016 Share Posted April 29, 2016 Real fake my blue, first number on list Already know that it's fake, got it free from my friend. This is working, but maybe don't take any risk to blow engine or then I do with one extra 4E n/a Quote Link to post Share on other sites
StuDoc 72 Posted April 30, 2016 Share Posted April 30, 2016 Or just the fact it lools fake lol Quote Link to post Share on other sites
AdamB Posted May 1, 2016 Share Posted May 1, 2016 You can tell that's fake by the quality of the clamps, hideous! Quote Link to post Share on other sites
triple j Posted May 1, 2016 Share Posted May 1, 2016 Mine had a big blow by due to the valve guide being of centre, my friend made me a new guide fitted it then drilled it out centre in the lathe, after that no problems. Quote Link to post Share on other sites
