Satrebla Posted May 17, 2016 Share Posted May 17, 2016 (edited) I just got a dashboard clock for my ep70, was wondering if there is any way to remove the plastic cover without having to remove the whole dashboard?I'm talking about this part http://imgur.com/IXSvlCX Edited May 17, 2016 by Satrebla Quote Link to post Share on other sites
MR-2 Posted May 17, 2016 Share Posted May 17, 2016 Yes it possible to take it out. There is plastic clips both side, first try bend lower part little bit with very small screwdriver and slide bigger ander that plastic. Try get it litle bit out and then try screwdriver to side. Use rubber cloves also to pul it out, hand inside box. That dasboard is very sort, so be careful without damagin it. Hands wont fit behind dasboard, that is sure. Quote Link to post Share on other sites
MR-2 Posted May 17, 2016 Share Posted May 17, 2016 Here You can see why not possible push from back. I just taked my clock surround away, because wanted to take dash out for spare part, one screw is behind that clockbox. Quote Link to post Share on other sites
MR-2 Posted May 18, 2016 Share Posted May 18, 2016 Sorry, wrong info about side clips, there is two up and two down, lower need to bend up first.I looked this morning from my gray Starlet, whic have installed Corolla clock, panel is destroyed when cutted box away and lost one clip also. Quote Link to post Share on other sites
Satrebla Posted June 10, 2016 Author Share Posted June 10, 2016 Sorry, wrong info about side clips, there is two up and two down, lower need to bend up first.I looked this morning from my gray Starlet, whic have installed Corolla clock, panel is destroyed when cutted box away and lost one clip also. Thank you very much for the info! Sadly, I was unable to remove it. As I'm trying to take it out, it feels like I'm forcing it a lot and don't really want to break it. Oh well, maybe I'll find a way somehow. Sorry for taking so long to reply Quote Link to post Share on other sites
MR-2 Posted June 22, 2016 Share Posted June 22, 2016 Your welcome. Why are You taking it away anyway? Corolla clock don't fit straight, it have to cutted also and it just laying there without screws, and no plug for clock, robbed it from cluster wiring. Quote Link to post Share on other sites
Satrebla Posted June 22, 2016 Author Share Posted June 22, 2016 Your welcome. Why are You taking it away anyway? Corolla clock don't fit straight, it have to cutted also and it just laying there without screws, and no plug for clock, robbed it from cluster wiring. I actually managed to take it out and yes, sadly it doesn't fit. I even had the plastic cover from a corolla, thought that maybe it would fit somehow :C Quote Link to post Share on other sites
