Neal2715 Posted August 27, 2016 Share Posted August 27, 2016 I have a ep91 n/a I stuck a galanza s intake mani in and now it revs like mad ? All pipes are connected the same way I took them off? New to doing cars up 😊 always had bikes does it have a idle screw? Quote Link to post Share on other sites
jordan walker Posted August 28, 2016 Share Posted August 28, 2016 On the top of the throttle body there should be a little black plastic cap (if it's still there) underneath that is the idle screw.Other than that I'd try having a look at your throttle cable (if you haven't already) with changing the mani you may have it too tight. Quote Link to post Share on other sites
Neal2715 Posted August 28, 2016 Author Share Posted August 28, 2016 Thanks for the reply it's got no plastic cap on top? Will it be because of too much air ? Also something strange appeared my temp needle has no gone way off the scale and is on the opposite side of where it's supposed to be lol (doesn't move) Quote Link to post Share on other sites
Starlet__SR Posted August 28, 2016 Share Posted August 28, 2016 Are you sure you havent mixed the coolant and vac pipes up? Quote Link to post Share on other sites
Neal2715 Posted August 28, 2016 Author Share Posted August 28, 2016 I put them on the same way I took them off ? Quote Link to post Share on other sites
Starlet__SR Posted August 28, 2016 Share Posted August 28, 2016 I put them on the same way I took them off ? Are you positive? Quote Link to post Share on other sites
Neal2715 Posted August 28, 2016 Author Share Posted August 28, 2016 Yeah marked them off as I tooked them off (numbered) Also to pic before hand Quote Link to post Share on other sites
Starlet__SR Posted August 28, 2016 Share Posted August 28, 2016 Is the throttle cable taught at idle? Is there a vacuum leak somewhere? Quote Link to post Share on other sites
MR-2 Posted August 29, 2016 Share Posted August 29, 2016 Do You have VSV in the end of intake chamber (turbo) or in the throhtle body (n/a)? You should be able adjust tb linkage also if cable adjust won't help... Quote Link to post Share on other sites
Neal2715 Posted August 29, 2016 Author Share Posted August 29, 2016 Is the throttle cable taught at idle? Is there a vacuum leak somewhere? I took the cable off the tb to eliminate it from the problem Quote Link to post Share on other sites
Neal2715 Posted August 29, 2016 Author Share Posted August 29, 2016 Do You have VSV in the end of intake chamber (turbo) or in the throhtle body (n/a)? You should be able adjust tb linkage also if cable adjust won't help... Yeah it has the plastic unit at the opposite end of the intake manifold Quote Link to post Share on other sites
MR-2 Posted August 29, 2016 Share Posted August 29, 2016 Yeah it has the plastic unit at the opposite end of the intake manifoldThis VSV is easier to try clean with some solvent, brake cleaner etc, try that before anything. Or take it away and block hole, no more high idle Quote Link to post Share on other sites
Neal2715 Posted August 29, 2016 Author Share Posted August 29, 2016 Brilliant will try that at the weekend Quote Link to post Share on other sites
