wammbamm Posted October 31, 2016 Share Posted October 31, 2016 Hi people first post, but I'm sure it's been asked quite a few times tried searching for a thread but came up with nothing that helpsA mate has found me a corolla inlet manifold for my 4efe engine and i want to know if it bolts straight on with no dramas and is there anything else I'll need to worry about.Also will I need the corolla throttle body or will the one on my starlet fit Go easy I'm quite new to modifying carsThanks Quote Link to post Share on other sites
SKINY Posted October 31, 2016 Share Posted October 31, 2016 Its very easy to do mate, remove the fuel rail and injectors to make it handy. There are a few pipes that you will need to adjust to fit too. I'm also using the Rolla throttle body too. Was dynoed recently at 86.6 hp standard is 74 so they do work Quote Link to post Share on other sites
wammbamm Posted October 31, 2016 Author Share Posted October 31, 2016 Thanks skiny,my mate said he is grabbing the rolla throttle body also looking forward to starting working on the car wanting to get the easier parts done first Quote Link to post Share on other sites
Russleh Posted November 1, 2016 Share Posted November 1, 2016 New inlet Mani gasket and tb gasket. Shouldn't need to remove any pipes from the tb but mark them if you do as it's easy to get muddled up. Finally there's a bolt onto a bracket from the underside of the standard inlet. Hard to see. Just have a good look at all the vac pipes on the standard Mani first and your sorted . Quote Link to post Share on other sites
wammbamm Posted November 1, 2016 Author Share Posted November 1, 2016 Thanks mate thats perfect will the gaskets be a ball ache to find it was hard enough finding the inlet mani Quote Link to post Share on other sites
morgey Posted November 1, 2016 Share Posted November 1, 2016 Need to tweak the throttle cable fitment too. A washer is used usually i think Quote Link to post Share on other sites
Russleh Posted November 1, 2016 Share Posted November 1, 2016 Gaskets are just standard ones for the starlet. Be cheap from Toyota if a trader on here cant hook you up. Also as above I used 2 big washers on the throttle cable. You'll know what we mean when you look at the cable mounting point and compare the 2 Quote Link to post Share on other sites
wammbamm Posted November 8, 2016 Author Share Posted November 8, 2016 (edited) So it's now fitted just the engine light comes on at idle and goes off when driving does anyone have any suggestions to what it is thanks Edited November 8, 2016 by wammbamm Quote Link to post Share on other sites
morgey Posted November 8, 2016 Share Posted November 8, 2016 Bridge the diagnostics bPort te1 and e1 and it should flash a code up. Quote Link to post Share on other sites
wammbamm Posted November 8, 2016 Author Share Posted November 8, 2016 Haha I'm not going to pretend I know what that means soooo.... I have to put my what in the what? Quote Link to post Share on other sites
morgey Posted November 8, 2016 Share Posted November 8, 2016 If you have an engine light you can find out what its for by getting a a bit of wire and bridging port te1 and e1 and turning the igntion on. The engine light will then flash a sequenceThe port is in the engine bay by the fuse box. If its a constant flash then its not much use as that means its fine but if its out of time you have to wait for the long pause and count them Will be like flash flash . flash ....... That would be 21.Then just google toyota ecu error codes Quote Link to post Share on other sites
wammbamm Posted November 8, 2016 Author Share Posted November 8, 2016 Thanks mate I'll give it a try Quote Link to post Share on other sites
fiddlersport Posted November 8, 2016 Share Posted November 8, 2016 The tps part numbers are different so ideally use your existing throttle body with new gasket to avoid this issueThe cable is slightly longer or shorter but still worksEarth on back of manifoldAll done Quote Link to post Share on other sites
