dan106 Posted February 19, 2017 Share Posted February 19, 2017 I fitted twin pots on my gt a few weeks ago, bled them up twice already, but the pedal still feels like there's air in the system, and there's a lot of travel till the brakes engage fullyAnyone else experienced this? Quote Link to post Share on other sites
Broony Posted February 19, 2017 Share Posted February 19, 2017 Most likely still air in the system. Take it for a hard drive then re bleed. make sure your bleeding it correctly.Failing this try a new master cylinder. Quote Link to post Share on other sites
glanzadude Posted February 19, 2017 Share Posted February 19, 2017 Is there anyway you put the caliper on the wrong side (ie) Drivers caliper on the passanger side and passanger side in the drivers side? Just saying it as i did that myself Quote Link to post Share on other sites
dan106 Posted February 19, 2017 Author Share Posted February 19, 2017 Na both bleed nipples are at the top of the calipers aha, I have taken it for a proper drive and re bled them, can't drive it too hard atm the clutch is roasted Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
morgey Posted February 19, 2017 Share Posted February 19, 2017 Another guy fitted a larger master cylinder to stiffen his pedal up. Have you gone around all the brakes or just the fronts? Quote Link to post Share on other sites
dan106 Posted February 19, 2017 Author Share Posted February 19, 2017 Is there anyway to adjust the pedal so it bites earlier? All round the brakes three times now, with Toyota dot 5 Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
morgey Posted February 20, 2017 Share Posted February 20, 2017 Think theres an adjuster under the dash at the top of the pedal Quote Link to post Share on other sites
ryan lang Posted February 20, 2017 Share Posted February 20, 2017 there is an adjuster at the pedal iirc. Quote Link to post Share on other sites
dan106 Posted February 20, 2017 Author Share Posted February 20, 2017 Think I'll give that a go see if it helps, is this a common thing with twinpots? It feels like my girlfriends saxo when one of her rear shoes weren't attached lol Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
ryan lang Posted February 20, 2017 Share Posted February 20, 2017 i had my pedal adjusted before fitting my brakes for an mot, so im guessing its just starlet brakes ahaha Quote Link to post Share on other sites
gorganl2000 Posted February 21, 2017 Share Posted February 21, 2017 I fitted twin pots on my gt a few weeks ago, bled them up twice already, but the pedal still feels like there's air in the system, and there's a lot of travel till the brakes engage fullyAnyone else experienced this? what size BMC is on your car at the moment? here you go boss..i had the exact same problem...that is the solution for me http://www.ukstarletowners.com/topic/102435-bigger-brake-master-cylinder/?hl=%2Bbrake+%2Bmaster+%2Bcylinder http://www.ukstarletowners.com/topic/103172-st202-brake-fade-issues/?hl=%2Bbrake+%2Bmaster+%2Bcylinder#entry1192928 Quote Link to post Share on other sites
dan106 Posted February 21, 2017 Author Share Posted February 21, 2017 I'd have to have a look, where'd you end up sourcing the bigger master cylinder from? Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
gorganl2000 Posted February 21, 2017 Share Posted February 21, 2017 read the 2 treads...everything is in there Quote Link to post Share on other sites
*Pete* Posted March 21, 2017 Share Posted March 21, 2017 I have celica ST202 twin pots, the starlet master cylinder was a bit weak so now I have my current master cylinder from a RAV4, slightly bigger than the starlet one and all bolts up the same. I do however have a slightly bigger one than the RAV4 from the same Celica which Im tempted to try. There is a measurement on the top normally, it is imperial though so get that phone out a convert it to mm (If you can't work imperial). I think the Starlet standard is 13/16, the RAV4 one I have is 7/8 which gives a nice pedal and the Celica one is 15/16 being the bigger out the three. Memorize the two bolt pattern on the servo and where the brake lines attach and go to your local scrap yard, try and see the measurement on top or unbolt it, take off the reservoir to see the number. When I went round my scrap yard I found it hard on some to see the number, either used my phone and tried to picture it or just took it off like I said. I believe Corolla's have 7/8 ones too, but dont hold me to that. Quote Link to post Share on other sites
dub-se7en Posted March 22, 2017 Share Posted March 22, 2017 I run 4 pots on the standard uk starlet BMC and servo no problem? was gonna suggest the upsidedown calipers problem but someone beat me to it, ahah Quote Link to post Share on other sites
gorganl2000 Posted March 22, 2017 Share Posted March 22, 2017 I have celica ST202 twin pots, the starlet master cylinder was a bit weak so now I have my current master cylinder from a RAV4, slightly bigger than the starlet one and all bolts up the same. I do however have a slightly bigger one than the RAV4 from the same Celica which Im tempted to try. There is a measurement on the top normally, it is imperial though so get that phone out a convert it to mm (If you can't work imperial). I think the Starlet standard is 13/16, the RAV4 one I have is 7/8 which gives a nice pedal and the Celica one is 15/16 being the bigger out the three. Memorize the two bolt pattern on the servo and where the brake lines attach and go to your local scrap yard, try and see the measurement on top or unbolt it, take off the reservoir to see the number. When I went round my scrap yard I found it hard on some to see the number, either used my phone and tried to picture it or just took it off like I said. I believe Corolla's have 7/8 ones too, but dont hold me to that. some toyota solara/camry model is suppose to have 1" BMC that should fit up as well when in installed the celica twin pot set up, i had the same issue with the stock 13/16 ep91 BMC feeling spongy and low...so i upgraded to the ep82 7/8" BMC and everything has been great---has a stock/sporty pedal feel....i did plan at some point to try the bigger 1" bmc from the camry/solora if i ever get the desire to go back at it---i think it will give that race car pedal feel Quote Link to post Share on other sites
