T0m Posted April 13, 2017 Share Posted April 13, 2017 (edited) So i bought an aftermarket ebc... But i can't really get my head around how the stock solenoid & the 2 pipes on the actuator work.On almost all cars actuators just come with one feed pipe which is connected to the compressor housing or with a T piece that connects to a 2/3 port solenoid... Once the pressure is reached within the charge pipes which is the same as the actuator spring, it's able to push to the diaphragm open which then pushes the wastegate open on the turbo's turbine housing regulating the exhaust gasses & affecting the pressure generated by the compressor... or if in case there is a solenoid, the solenoid bleeds of the extra pressure untill it's desired pressure is reached... So how does the second pipe work connected to the solenoid,... if it is blocked does it adjust the diaphragm so that it opens more quickly or does it need be able to vent to open more quickly, or does it work in a completely other way ?The pipe on the right connects to the compressor housing and normally with only that pipe connect you should run wastegate pressure 0,65 bar What does the pipe on the left do or is the stock wastegate pressure only 0,35 and does the second pipe act as a bleed pipe to the solenoid ?In that case the solenoid shuts the air circuit when low boost is enabled and with high boost it opens the circuit and vents the air back into the EFI pipe ? so if my theory is correct you should leave the left pipe on the actuator just vented to atmosphere and install the T piece for the aftermarket solenoid between the right actuator pipe & the compressor pipe? Edited April 13, 2017 by T0m Quote Link to post Share on other sites
maerijn Posted April 13, 2017 Share Posted April 13, 2017 You are correct about the T piece, however you have to block the left pipe, dont vent it to atmosphere Quote Link to post Share on other sites
T0m Posted April 14, 2017 Author Share Posted April 14, 2017 so blocking the left pipe ups the stock wastegate pressure to 0,65 instead of 0,35 Bar ? Quote Link to post Share on other sites
