Sign in to follow this
ashep91
What's glanza parts are interchangeable
So I am trying to get a list of parts that off a normal UK spec glanza will fit an import in a recent search for a part after ringing Toyota I have found I could have brought the same part that fits a UK spec glanzas saved a ton of money does anyone have a list of interchangeable parts
Share this post
Calipers are the exact same but carriers are different.
Brake discs on glanza are bigger
lower control arm buses are all same size.
Drop links are different due to glanza using different style end on the anti roll bar
handbrake cables are different as far as I know
rear breaks uk spec has drums
Share this post
Most things on the engines and interior are interchangeable
Share this post
Engine wise
crank is the same
conrods and pistons are different
cams are the same
valve springs are different
A uk block doesn't have a knock sensor although it does have a location for one.
Sumps are the same apart from the oil return from turbo
Share this post
Create an account
Register a new account
Sign in
Sign In Now
