5efte won't start without easystart
Could be a number of things... have you checked/set the static timing? (bridge out the two pins on the diagnostic plug to lock timing, set to 10 degrees btdc)
ECU coolant temp sensor?
TPS?
ICV?
etc...
unplug (or change if you have spares) one sensor at a time and see if anything changes
  • 3 weeks later...
Changed sensor still won't fire first kick, it'll start and run if I spray fuel/easy start into throttle body tho and it'll run fine, although when it's cold if I press accelerator it dies down and nearly cuts out unless I tap accelerator lightly to bulld up revs any ideas?
