Sign in to follow this
GRB
Automatic conversion
I've just bought an automatic glanza and i have another glanza to do the conversion with so everything to do the job should be there. Just looking for some advice on how to go about doing it etc? Any help would be appreciated cheers👍🏽
Share this post
Its a pretty straightforward job, that will probably turn into a more time consuming job as you go and the while its apart opportunities appear lol. Its best to just pull the engine and gearbox as one, do the swap out of the car, refreshing gaskets here and there as you go. Makes drilling a hole for the clutch master cylinder etc easy, and whe youre done you can be sure you wont have to pull it back apart for a while!
Ive literally just finished doing my own conversion, feel free to message me if you get stuck!
Edited by Chops
Share this post
Cheers for the help buddy. Il be starting this weekend so will give you a shout if I do get stuck thankyou 👍🏽
Share this post
Create an account
Register a new account
Sign in
Sign In Now
