Does gt turbo loom work on NA turbo engine
Got a mk3 gt rolling shell just needs engine and gear box was going to get an na engine put turbo pistons in it and try run that but was unsure wether the loom would run that engine
ya sweet that will work loom will plug right to the rest of the loom in your gtt
but again turbo sensors , injectors , coil/dizzy . TB , MAP , AIT , KNOCK and ecu needed you can run all strait fit when you have the loom just need to tap the thread for the knock sensor right next to the waterpump its M12 X 1.25
yes you can swap over 4efte pistons in the 4efe like me turbo G.I. block ( 100bhp N.A. ) lasted years
