Craigtrials95 Posted May 20, 2017 Share Posted May 20, 2017 Going to be running externally gated setup on my 5e once its built and ive never had an external setup before so after some info.If i get a wastegate with say a 0.8 bar spring i can then up the boost to 1.0 bar and 1.4 bar with an electronic boost controller? Thats my understanding anyway just want to make sure its correct Cheers Craig Quote Link to post Share on other sites
Gainzy Posted May 20, 2017 Share Posted May 20, 2017 0.8 spring will do the job Quote Link to post Share on other sites
maddox710 Posted May 20, 2017 Share Posted May 20, 2017 What ever spring you choose that will be the base pressure I.e can't go lower than that value so choose wisely and on what sort of pressure you want to run. Quote Link to post Share on other sites
Craigtrials95 Posted May 21, 2017 Author Share Posted May 21, 2017 Cheers lads vf035 turbo so probably go for a 0.8 bar spring Quote Link to post Share on other sites
