Sign in to follow this
Followers 0
Best anti lift kit?
4 posts in this topic
Any thoughts which is the best anti lift kit on the market, giving the most castor?
Powerflex, standard bush or black bush
Or Whiteline?
Cheers
Share this post
i not seen any differance between white line or power flex they both have sloted holes. the bushes on the white line used too pop out but this was when they first made them back in 2007 since a few complants they made the bushes without the slit. ive used both the problem you will have the more + castor you add the more strain you add too the front bush. try go another route if its track car only ( rose joints )
regards gee
Share this post
Thanks Guys,
Yes ideally Gee, id gain alot more castor through rose joints/adjustable top mounts. Sadly both are not allowed within my regulations.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
