Stuck in the rain changing pads help please
It is all the way in pal(see below), I used a g clamp to squeeze the piston all the way in.... the front pad seems to be sit above the bracket, is that right?Posted ImagePosted Image
Sent from my Redmi Note 3 using Tapatalk
RED part sliders
Green part caliper
Blue part carrier
The blue part should move in and out from the green part on the red parts...... the red parts are probably seized.
Posted Image
Sent from my SM-G935F using Tapatalk
Thanks alot fellas, I would normally have the help of my dad but he got drunk and passed out so I was left to do it myself. I would have waited till the weekend for this but as you can see from the pictures below, they're dangerouse9b0d8b0b6e96bdc7e66f7943c067764.jpg5de075511c09355a3ab38ba109ce8ab6.jpg
Edited by Shyam
With your help, I've managed to get the pads into the calipers and get them bolted back on the car. After putting the reservoir cap back on, and going for a quick spin, I noticed my brakes are spongy as fuck... Do I need to bleed them?
Edited by Shyam
  • 2 months later...
