Andrew Miller Posted September 22, 2017 Share Posted September 22, 2017 The car will idle around 1500rpm sometimes up to 2000rpm all the time. Occasionally it will drop back to normal then back up to 1500 again. Ive replaced the idle control valve, coolant temp sensor and smoke tested it to no avail. Any ideas? Quote Link to post Share on other sites
craigyboi Posted September 22, 2017 Share Posted September 22, 2017 Does it drop if you give the accelerator a little blip ? You tried cleaning the little butterfly thing in the inlet manifold? Sometimes stick open a little. Quote Link to post Share on other sites
Andrew Miller Posted September 22, 2017 Author Share Posted September 22, 2017 Reving it even lightly makes zero diffetence unfortunately Quote Link to post Share on other sites
federalman Posted October 23, 2017 Share Posted October 23, 2017 I'd clean the butterfly valve (next on my to do list) failing that give the idle control valve a clean. I did mine and it settled back down though I think i damaged the thin metal gasket type bit inside as mine started playing up again. I tend t o just adjust the idle screw and it settles back down again, though I tend to like mine to idle between 1000-1200, Quote Link to post Share on other sites
