ashford_ep91 Posted October 2, 2017 Share Posted October 2, 2017 Finally got JTs Glanza at the weekend. My god its good to drive! Only issue I have is 2nd, and occasionally 1st can be tight to select. All other gears are ok. I can drive around it, but my wife isnt finding it so easy. Ive read about a bush on the selector linkage at the gearbox end - anyone have a picture of this? Can the linkages be adjusted side to side? Cheers. Quote Link to post Share on other sites
shaq Posted October 3, 2017 Share Posted October 3, 2017 No adjustment,lube your cables and grease/lube shifter,wd40 moly spray,you can cut the cable cover a small bit spray.seal it with any adhesive and rubber.check the tube.I had the same issue SOmE times can be cut worn bush not keeping the cable straight just have a look lube the ends can work too. Quote Link to post Share on other sites
