Sign in to follow this
Followers 0
Td04 mildsteel mani/downpipe on eBay
10 posts in this topic
Browsing eBay as you do I came across this set up, even though it’s toyosports it clearly states mild steel, and I’m thinking its to good to be true at that price? Thoughts anyone?MILD STEEL MANIFOLD & DE-RESTRICT CAT REMOVAL TOYOTA STARLET EP82 EP91 TD04 https://www.ebay.co.uk/i/382154907884
Share this post
They are know to crack. These need bracing and the flange faces machining flat especially on the head flange, if there not flat they are known to crack the aluminium on the N/S of the head exhaust stud.
Share this post
These are the new Design thicker wall there worth the money  when extra bracings are welded to cat and manifold they last years   just. Check if there's no warp like Luke mentions. But mine never where tho
Share this post
Thanks guys for the tips, I had a td04 kit, ended up selling it, now thinking maybe not, but then I wanted the tf035 turbo like you have said in the past Colin not a tdo4
Share this post
ya tfo35hm is a GREAT GREAT turbo on a stock 4efte
or a ct12B ( 43mm inducer hi hi )  with a ct9b turbine shaft and exhaust housing  2 turbos i stand by   and is 1 i have in the making right now
Edited by 5e colin
Share this post
Please keep me posted on that one Colin, staying stock 4efte, so very interested what you come up with :-)
Share this post
Oh Colin sorry should of said meant the ct12b you have in the making.
Share this post
4mm thick steel wall I'm just reading Colin, have you used this kit then and what's it like ? I've just bought that tf035 of Gibb :)
No real rush for a kit just wondering
Share this post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
