jellybaby Posted November 23, 2017 Share Posted November 23, 2017 Hi all I looking at if it poss to go for hydraulic lifters with inner shim to emliminate the risk of cam lobes pushing the shims out Quote Link to post Share on other sites
morgey Posted November 24, 2017 Share Posted November 24, 2017 I dont think hydraulic will be an option as you'll need a oil supply to the outer edge of the lifter body to allow the lifter to pump up so to speak. You could get solid under bucket lifters from a yaris although im Not sure what model engine. This only needs doing if using big cams though. Quote Link to post Share on other sites
daniel_g Posted November 24, 2017 Share Posted November 24, 2017 http://www.ipg-supertech.com/Toyota/ This lot is ment to fit a 4e head Quote Link to post Share on other sites
