I mean it does depend on how decent a job and what not.
I was under the impression you can get 6PSI out of the 4E engine.
In which case you will want a CT9, should be plenty kicking about as people upgrade for th TD04, manifolds, down pipe, injectors.
Yeah I can see where Nick is coming from now.
If you can nab someone off the forum who is tuning their CT9 to a TD04 you could do it fairly cheaply, but it won't last as long as a normal GT/Glanza
