Rear Brake Pads
10 posts in this topic
Hey guy's
Hope you all had a good Christmas!
Sorry if this is already been posted but my work computer has classed the words "brake pads" as pornography so I can't search for it.... makes sense
Anyway I'm changing the brake pads on my Glanza tomorrow and I was wondering is there any difference when changing them?  I've changed the fronts before and that's simple enough, I assume the rear is much the same but just wondering if there's any difference before I get stuck in.
cheers peeps
Share this post
Hi,
I've just finished replacing the front and rear discs, pads and rebuilt the calipers on my glanza.
It's very simple.
Simply undo 2 caliper bolts remove the caliper / suspend it with a cable tie from the shocks / spring, then there are 2 more bolts holding the pad carrier to the hub. remove those.
Take the pad carrier away and swap out the old pads with new pads with the clips in the same way.
Then you'll have to rewind the caliper piston. I bought a rewind kit so I have it for the future but you could use say pliers in the grooves. Wind the piston all the way back.
Bolt the pad carrier back on to the hub / brake disc with the 2 bolts that you undid.
Bolt the caliper back on, 2 bolts and that's it!
Share this post
34 minutes ago, Farley V said:
Hi,
It's very simple.
Mate you're a star! So you change the front and back exactly the same:thumbsup: nice one buddy
Share this post
That's enough recommendations for me! I'll defo be picking one of these kits up. I've got one really stupid question left, when I changed my pads before a friend go me a set from his work. This time I'm getting a set of Yellow stuff pads from ID Workz but I don't know how many boxes I need to buy. do they come in sets of just 2 or 4? the last ones I had came in a set of 4 but I don't wanna buy 2 boxes of these and have extra pads that I don't need!
thanks guys!
Share this post
36 minutes ago, JamesD89 said:
The set of 4 will come in one box mate.
James
Nice one cheers bud:thumbsup: No more daft questions from me lol well until the next problem comes up!
Share this post
Create an account
Register a new account
Sign in
Sign In Now
