4E-FTE speed limit ,solution to remove ?
Hi everyone,
I almost done my  4e-fte engine swap in my EE90. I wait new sparks plugs to start it.
To waiting , i finished the wiring. I saw what my pin-out 9 " speed sensor is cut . So i think , the ECU will be in default ( code 42 ).
But i would like to know if this fault code brings a" limp home"  mode  ?
I had think  to take a speed signal to my speedometer but mine is entirely mechanical, no electric wire ...
So i thought to a another solution , install a SLD , but it costs expensive :o
I would like to see with you if anyone has a good adress to order one it , or to sell it .
Thank you ;)
