Zisco inlet manifold
11 posts in this topic
Hi all.
Started progress on an engine build recently purchased a zisco inlet along with thermal gaskets etc going to be running standard throttle body for now along with td04.looking for advise on installation and pics if possible for plumbing in all the pipe work.any feedback on gains on td04 or losses would be much appreciated.
Share this post
Low down torque will be lost Luke but great top end gained as the stock 4efte intake chockes/restricts top end that's why I run a acis for the ability to use both torque and top end . depending which type you going to need to get a 2E throttle cable as the 4efte is going to be to short and intercooler pipe will need modding to on some
Edited by 5e colin
Share this post
Hi Colin.Thank you for the advise good shout on the throttle cable didn't think about that.ill have to see if I can get one before I start pulling to bits.The Acis manifold is sounding more interesting are they hard to come by.
Share this post
For zisco inlet. The oil dipstick will need bending slightly.
Regarding power. Mine makes 30bhp up top with same tourque figjre just peak tourque is 700rpm later.
Also get a bracket made for extra support like oem inlet has.
Share this post
That sounds pretty good id be happy with any gains like that.
Thank you for the advise will try and do a guide when I got mine for future reference.
Thanks again
Share this post
Check flange face is straight. Mine eventually warped so getting that repaired and few little mods for top end gains.
Share this post
Thanks for the advise ill check that.might just put it on machine quick give it a skim.
Hope to get it on the weekend going to use standard throttle body for now hopefully works out well
Share this post
Ive got the race spec so a 70mm throttle body.. see if you can get someone to make a support bracket for it. The engine vibrations eventually crack it
Share this post
I'l hopefully get some measurements on the weekend and do a cad model then machine up a bracket cheers for the advise.
Luke
Share this post
Create an account
Register a new account
Sign in
Sign In Now
