Hi all.
Started progress on an engine build recently purchased a zisco inlet along with thermal gaskets etc going to be running standard throttle body for now along with td04.looking for advise on installation and pics if possible for plumbing in all the pipe work.any feedback on gains on td04 or losses would be much appreciated.
Low down torque will be lost Luke but great top end gained as the stock 4efte intake chockes/restricts top end that's why I run a acis for the ability to use both torque and top end . depending which type you going to need to get a 2E throttle cable as the 4efte is going to be to short and intercooler pipe will need modding to on some
Edited by 5e colin
8 minutes ago, jayc-glanza17 said:
For zisco inlet. The oil dipstick will need bending slightly.
Regarding power. Mine makes 30bhp up top with same tourque figjre just peak tourque is 700rpm later.
Also get a bracket made for extra support like oem inlet has.
That sounds pretty good id be happy with any gains like that.
Thank you for the advise will try and do a guide when I got mine for future reference.
Thanks again
