JamesD89 Posted February 23, 2018 Share Posted February 23, 2018 (edited) Hello all, bit of a story here so please bare with me. I changed the oil on the glanza and whilst topping up through the filler cap I managed to drop a 10 litre bottle all over the engine bay. And surrounding walls etc. I cleaned as much as I could of it up straight away but I stupidly failed to notice its all over the bottom of the air filter. Driving to work today got on boost and at around .2 bar the turbo screeched and I lost all power. Foot to the floor and the car doesn't move. Just wondering what potential damage this could of done and what's best to do next. I've taken the intake pipe of to clean and il bin the filter but does the turbo need to come off for rebuilding etc?. Sorry for the essay. Cheers James Edited February 23, 2018 by JamesD89 Quote Link to post Share on other sites
maddox710 Posted February 23, 2018 Share Posted February 23, 2018 Does it start and drive with filter off?? Quote Link to post Share on other sites
JamesD89 Posted February 23, 2018 Author Share Posted February 23, 2018 It's starts and runs fine but as soon as I get on boost it loses all power, rev needle doesn't drop but the car won't move . I have to bring the car to a stop and then its fine again. Was quite shitty in the outside Lane of dual carriageway though. Cheers Quote Link to post Share on other sites
maerijn Posted February 23, 2018 Share Posted February 23, 2018 (edited) Screeching turbo sounds like an inbalance which would mean a worn turbo (bearings gone, no oil?). When the turbo is worn it can jam and block the inlet and reduce power. Did you fill it up to the correct level to begin with? Edit: take of your air filter and check for any play on the compressor wheel Edited February 23, 2018 by maerijn Quote Link to post Share on other sites
Shyam Posted February 26, 2018 Share Posted February 26, 2018 I wouldn't risk driving it at all if I were in your shoes pal.. Take intercooler off and give it a good thorough clean, remove all oil out of it, then do a compression check on all cylinders mate. If you want peace of mind, remove and rebuild turbo and replace intercooler/piping. Also check your intake manifold, injectors etc, If your unsure where to rebuild turbo, I've had my CT9 hybrid turbo rebuilt at Midland Turbo, and can vouch for them. They do high quality work on short lead times. Quote Link to post Share on other sites
5T4R7ET N/A Posted February 27, 2018 Share Posted February 27, 2018 Check the hoses for oil inside them, intercooler piping and the small hoses from the turbo to the any thing in your setup. Then after you have made oil is all gone, check turbo for shaft play and see if its spinning freely. Quote Link to post Share on other sites
NippyNippon Posted March 6, 2018 Share Posted March 6, 2018 Oil getting in the inlet would just be burned in the combustion process. So shouldn't do too much damage in that respect unless it was sucking in huge amounts. I doubt it would be loads if was coming through a filter. How do you know it was the turbo that screeched? Sure it wasn't a belt? (Cam/alternator etc...) Did you clean under the cambelt cover? Oil may have caked a sensor somewhere in the inlet or you may have disturbed a sensor in the bay when cleaning. This could cause power loss. Quote Link to post Share on other sites
