you going to have to get a custom cradele made to hold the crank in place or she will walk out of the block
instead of 5 caps holding the crank 1 solid custom machined unit to keep her tight  youd be max porting the head  for sure
plenty more that needs doing  tbf
On 12/03/2018, 4:35:57, Calum122 said:
Tidy, why do you need the high RPMs?
Is there any power to make it in that region?
Well there is if I build it right.
  • 4 weeks later...
On 12/03/2018, 15:50:56, ChaseWheatley said:
I’m fitting titanium pauter rods. Custom ti valves and springs. Custom dry sump. I’m running a Garrett gtx2860r gen 2 turbo atm. I’ll change and make tweaks as I go. I’ll changed the cans if needed after testing
Interesting! How far along in the build are you?
  • 4 weeks later...
That setup won't make any power beyond 6500rpm.
  • 4 weeks later...
On 09/05/2018, 7:21:27, H_D said:
Good luck if you plan on using the stock main caps.
I’m having custom ones made my friend and a one off forged crank.  But I may not use ti rods but a light rotating mass would be better just shitty about the ti fatigue life
Custom crank for the price of a turbo kit sounds cheap to me! Who’s doing the work?
You can already buy billet caps off the shelf in America.
What ecu are you planning to use that can cleanly trigger to 11,000-11,500 rpm?
And engineering company in NZ.
I know I can but I might as well just get it all made at the one place.
