William737 Posted November 29, 2018 Author Share Posted November 29, 2018 Reckon it would be this causing the noise in the video? Quote Link to post Share on other sites
Padders Posted November 29, 2018 Share Posted November 29, 2018 1 hour ago, William737 said: Reckon it would be this causing the noise in the video? Hard to diagnose a fault over a 5 second video. Is there no clearance at all? Quote Link to post Share on other sites
William737 Posted November 30, 2018 Author Share Posted November 30, 2018 No clearance Quote Link to post Share on other sites
Padders Posted November 30, 2018 Share Posted November 30, 2018 9 hours ago, William737 said: No clearance Oh dear, inlet or exhaust? Was it just on one? Quote Link to post Share on other sites
William737 Posted November 30, 2018 Author Share Posted November 30, 2018 Just one lobe Quote Link to post Share on other sites
William737 Posted November 30, 2018 Author Share Posted November 30, 2018 I think I am just going to change the cams over as I have spare ones Quote Link to post Share on other sites
jellybaby Posted November 30, 2018 Share Posted November 30, 2018 15 minutes ago, William737 said: I think I am just going to change the cams over as I have spare ones No need all u have to do is sort that one shim out if the rest are in tolerance Quote Link to post Share on other sites
William737 Posted November 30, 2018 Author Share Posted November 30, 2018 30 minutes ago, jellybaby said: No need all u have to do is sort that one shim out if the rest are in tolerance Okay cool, so perhaps use a shim from my other engine? Quote Link to post Share on other sites
Padders Posted November 30, 2018 Share Posted November 30, 2018 1 hour ago, William737 said: Okay cool, so perhaps use a shim from my other engine? Yes just select a shim that is suitable. Does it start ok? I find it strange that all of a sudden one valve has no clearance. As I said, worn valve or valve seat. Hope the piston isn't touching the valve...hence what the noise might be. Quote Link to post Share on other sites
William737 Posted December 3, 2018 Author Share Posted December 3, 2018 Starts fine, yeah thought the same is a bit strange isn't it... I'm gonna get it apart on Saturday and swap the shim over etc, I'll post if I find anything. Quote Link to post Share on other sites
William737 Posted December 8, 2018 Author Share Posted December 8, 2018 So had a good look today, swapped some shims about etc. The other shims I had also provided no clearence, the sound changed with different shims I believe this is where the sound is coming from. Does anyone know of a good place I could find some shims for sale? Quote Link to post Share on other sites
jellybaby Posted December 8, 2018 Share Posted December 8, 2018 If they are to thick any good engineers will a b able to reduce the thickness for u ob if they to thin then u need to get a replacement Quote Link to post Share on other sites
William737 Posted December 8, 2018 Author Share Posted December 8, 2018 33 minutes ago, jellybaby said: If they are to thick any good engineers will a b able to reduce the thickness for u ob if they to thin then u need to get a replacement Okay cheers Quote Link to post Share on other sites
William737 Posted December 8, 2018 Author Share Posted December 8, 2018 The thickness of the shims were 2.50mm and there was no clearence so I'll have to go thinner? Quote Link to post Share on other sites
