1 hour ago, William737 said:
Reckon it would be this causing the noise in the video?
Hard to diagnose a fault over a 5 second video.
Is there no clearance at all?
Share this post
9 hours ago, William737 said:
No clearance
Oh dear, inlet or exhaust? Was it just on one?
Share this post
15 minutes ago, William737 said:
I think I am just going to change the cams over as I have spare ones
No need all u have to do is sort that one shim out if the rest are in tolerance
Share this post
Okay cool, so perhaps use a shim from my other engine?
Share this post
Yes just select a shim that is suitable.
Does it start ok? I find it strange that all of a sudden one valve has no clearance. As I said, worn valve or valve seat.
Hope the piston isn't touching the valve...hence what the noise might be.
Share this post
Starts fine, yeah thought the same is a bit strange isn't it... I'm gonna get it apart on Saturday and swap the shim over etc, I'll post if I find anything.
Share this post
So had a good look today, swapped some shims about etc. The other shims I had also provided no clearence, the sound changed with different shims I believe this is where the sound is coming from. Does anyone know of a good place I could find some shims for sale?
Share this post
33 minutes ago, jellybaby said:
If they are to thick any good engineers will a b able to reduce the thickness for u ob if they to thin then u need to get a replacement
Okay cheers
Share this post
Create an account
Register a new account
Sign in
Sign In Now
