Sam259 Posted December 1, 2018 Share Posted December 1, 2018 What size injectors are people running with td04? Quote Link to post Share on other sites
Calum122 Posted December 1, 2018 Share Posted December 1, 2018 How much power you looking to make? Quote Link to post Share on other sites
Sam259 Posted December 2, 2018 Author Share Posted December 2, 2018 9 hours ago, Calum122 said: How much power you looking to make? Would 220bhp be reasonable on the td04? Quote Link to post Share on other sites
Calum122 Posted December 2, 2018 Share Posted December 2, 2018 1 hour ago, Sam259 said: Would 220bhp be reasonable on the td04? You'll wanna read that then bud. Quote Link to post Share on other sites
RobSR Posted December 2, 2018 Share Posted December 2, 2018 If you’re only after 220bhp stock are fine. Quote Link to post Share on other sites
Maxep Posted December 4, 2018 Share Posted December 4, 2018 Running a td04 on 1 bar with stock injectors. Should be fine for the power you're looking for. Quote Link to post Share on other sites
glanzadude Posted December 8, 2018 Share Posted December 8, 2018 Are you not really over running the stock injectors at 220 as that is 90bhp over like? Quote Link to post Share on other sites
RobSR Posted December 9, 2018 Share Posted December 9, 2018 16 hours ago, glanzadude said: Are you not really over running the stock injectors at 220 as that is 90bhp over like? No it’s fine. You’re pushing it when you’re getting around 240-250. Quote Link to post Share on other sites
Healey Posted December 18, 2018 Share Posted December 18, 2018 If you're worried about it, I used some yellow 450cc rx8 injectors that I got for £90 refurbished on eBay Quote Link to post Share on other sites
Telex Posted December 20, 2018 Share Posted December 20, 2018 On 12/18/2018 at 11:01 PM, Healey said: If you're worried about it, I used some yellow 450cc rx8 injectors that I got for £90 refurbished on eBay Are these injectors direct fit (inc. electric plugs)? Hi or low ohms? Quote Link to post Share on other sites
Healey Posted December 20, 2018 Share Posted December 20, 2018 They are high and are a direct swap, get your tuner to put them when you go for a map Quote Link to post Share on other sites
Telex Posted December 20, 2018 Share Posted December 20, 2018 Ok, thanks Quote Link to post Share on other sites
dcbr Posted September 9, 2019 Share Posted September 9, 2019 On 12/20/2018 at 5:49 PM, Healey said: They are high and are a direct swap, get your tuner to put them when you go for a map Have you got the link for these injectors mate. I had a fuel rail to go on but I need to buy an-6 to 8mm fuel pipe fittings etc etc. Seems a bit of a headache to do when there is direct swap injectors. Quote Link to post Share on other sites
Duduglanza Posted September 13, 2019 Share Posted September 13, 2019 450cc without fuel managment of some type.. will have you car run rich. if atill using a stantard ecu with fcd .. just go for 360cc. Quote Link to post Share on other sites
