Valve Assy, Air By-pass?? IModifying air filter intake
Hi everyone, I am about to install a Front mount intercooler and was also thinking of installing an aftermarket air intake system (pod filter) as it looks like I'll have to do this to make room for the long fmic pipe on the drivers side coming up past the battery to the throttle. Just need advice from you lads who have done this. See attached pic of my bay. What do I do with the " valve Assy air by pass?? Any advice to save me reinventing the wheel would be great
Cheers
Laurie Rogers
1998 Toyota Starlet Life transforming into
a Glanza V
L
ve Assy, Air By-passValve Assy, Air By-pass?? Valve As
The part you have circled is essential the stock recirculating valve (like a dump valve but goes back into the intake).
Best thing for you to do is to connect it to the take off in the silver pipe to the far right of your pic. The other side an go to atmosphere.
You will need to keep the small vacuum line that runs to the top of it, you can use any sort of silicone hose to replace this with a longer one
