The difference between N/A and Turbo headlights + short howto!
i thought this may come in handy for future reference.
i remember looking for pics like this for ages, now i have them myself so i thought i'd better share :thumbsup:
there you go!
to swap them is pretty easy i must say. forgot to make detailed pictures! but here is the step by step explanation:
-Undo lightclips, like when replacing bulbs
-Remove indicator by unscrewing top lil screw and pulling it the indicator forward.
(the indicator is connected at the bottom with a pin in a hole (#1 on picture))
-undo bolt with spanner(10mm)(#2 on picture)
-the headlight is now still connected on 2 spots(#3 & #4)
-on spot #3 to loosen, you have to lift the light
-on spot #4 to loosen, you have to move headlight towards the indicatorside(this is the reason you need to remove indicator, you need the space)
-both spot 3 and 4 should come loose at the same time.
thats about it you have the headlights loose now.
hope its off any use!
  • 3 months later...
http://img.photobucket.com/albums/v697/Kev...t/headlight.jpg
Thanks Kevin K! I just had to replace a headlight for the MOT and your post saved much head scratching, as I cannot find a workshop manual for the Starlet. I'm used to 1960's cars- modern stuff is a mystery- so your diagram was excellent help.
Cheers a bunch!
John
  • 4 months later...
  • 2 years later...
