Callan Posted February 7, 2009 Share Posted February 7, 2009 Right here we go, say if you need to stop an annoying rattle(like i did) etc this shows a quick view of how its doneTheres 4 screws you need to remove, theres 3 large ones under the arm rest........and a small one in the handleThe rest will fall off when the 3 large screws are removed...push the handle forward towards the front of the car...And then it will pull out towards youThe door card then just pulls off by clips around the edge of itThere you go, reverse what youve done to refit, be careful not to snap or loose the clips in the door card Link to post Share on other sites
