Jam Racing Glanza Specs
you guys might have seen the vid in the news blog of the Jam GLanza vs Boss evo. its in the side bar of the blog.
ive been watching it a bit recently and im amazed at this car. its cracked a 1.02 around Tsukuba
now i have a cusin that stays in osaka. and he has agreed to decipher the text, and dialect.
he sent me this email of the spec from in the video here
JAM RACING STARLET
Engine ______1500 complete
Highcam ____Jam
Turbine______Normal CT9( High-flow )
Intercooler __Jam front-mount kit
Mission______Normal
Clutch ______AP twin
LSD ________TRD 15WAY
Final 4.3
Damper___TRD
Spring_____TRD Front: 14kg Rear: 12kg
Brake_____Front: WILWOOD 4POT
Pad Front: WILWOOD Rear: JamRC
WILWOOD Brake balancer
Tyre______YH A048
F225/ 45R16 R215 / 50R16
Car Weight______848kg
Horse power______250
now with that same power and setup it did a 1.02.886 seconds around Japans Tsukuba circuit.
food for thought here are some times of stock cars for comparision. it would put it next to this little lot
Nismo Skyline GT-R Z Tune 1 min 01.150 secs
Ferrari 360 Challenge Stra' 1 min 02.440 secs
Lamborghini Gallardo 1 min 03.605 secs
Honda NSX-R 1 min 03.920 secs
McLaren F1 1 min 04.620 secs
Porsche 997 Turbo 1 min 04.730 secs
Murcielago 1 min 04.760 secs
Z-Tune 1 min 05.100 secs*(diff day diff driver)
EVO IX RS 1 min 05.528 secs
997 Carrera 4 1 min 05.980 secs
Corvette Z06 1 min 06.020 secs
Lancer Evo IX 1 min 06.060 secs
NA1 NSX-R 1 min 06.198 secs
Nismo GT-R S Tune 1 min 06.232 secs (340 bhp)
Ferrari F40 1 min 06.460 secs
WRX STI SPEC-C 1 min 06.651 secs ( Current STI)
NA1 NSX-R 1 min 06.80 secs (same race as F40)
BMW M5 1 min 06.560 secs
STI S204 1 min 06.800 secs
BMW M6 1 min 07.434 secs
350Z S Version 1 min 08.110 secs
BMW M3 1 min 08.200 secs
Audi RS4 1 min 08.368 secs
Supra Euro Version 330 bhp 1 min 08.460 secs
Mazda RX-7 1 min 08.70 secs
RX-8 A Spec 1 min 09.430 secs
Nissan 300ZX 1 min 10.70 secs
clicks of when it did that time are here.
ive watched that vid loads of times and looked at the revcounter, and it looks like an amazing low lag track setup.
in that tune hes getting 250brake from a high flow ct9 + 5e combo but the delivery of power looks so smooth
does anyone know of the engine specifics of whats actualy in a jam engine. or more interestingly the specs of the cams they put in this 5e.
or more importantly the spec of the hi flow turbo? it uses a jam actuater??
that
is
sick!
i never would ave thought it was running a ct9 !!
anybody an idea how much boost it was running on? as known a ct9 runs out of air above 1 bar..
highflow ct9? other word for hybrid?
shame they didnt race (evo vs JAM) sounds like the jam glanza had troubles with the brake cylinder master?? and from the look of the brake pedel he almost had no brakes lol!
either way that jam glanza is pretty mental, i'm sure the hybrid turbo has been worked almost to the max of the ct9 housing. so quite a big comp blade and perhaps a 360 trust bearing?
i'm sure you know marks glanza (www.glanza.co.uk) well he sold it onto my mate, and that seems to have quite alot of jam items and hks so can only imagine that the person who built the car in japan had influence from the jam beast. he has some high lift hks cams running is his but i'm sure jam would have put in some high lift variations of there own so the turbo doesnt spool so silly hard and die out perhaps shifting the delivery to around 4k full boost?
also the ecu my friends car is running is a custom mapped original ecu... so the stock 4efte has been chipped in japan (possible by jam) so again i'm sure jam had there own ecu in but mapped alot more aggressively then any other 'stock' jam ecu.
yea i have starlet bible at home but its all in squigly writing.
i hi flow turbo is differnt to a hybrid in that only the waistgate gets board and compressor wheel modified to flow more air.
thats a hi flow turbo
a hybrid in the true sense of the word is when you start using different compreessor - turbine,shaft wheel combinations.
im thinking is this figure is possible on a hi flow turbo(like the gt spec) i wander what a td12 would be like on a 5e like that!
thanks for clearing that up, keep learning things every day :thumbsup:
Rob is right about the Jam Glanza going through different phases. Also when it had the 4E in it, it recorded a 1'04".865 round Tsukuba. Still awesome. It's definitely my favourite Starlet ever made, does anyone know what has happened to it? Do Jam still own it or sold it on?
In my bordem today and interest in Jam cars I did some trawling of the archived files from the Jam site and came accross a whole host of stuff I never knew about them..... unfortunatly there site becomes unaccessable after Oct 04 due to a formatting issue i think, which is when pics of the 5e Glanza start appearing....there is a whole host of stuff hidden in the past of there website from magazine articles to them working on customers cars passed a good few hours it did....if i get chance ill bang it all together in a post.....but for now i did manage to pull this off though when it was 4e spec straight from the jam site when it was actually for sale
JAM RACING WORKSCARS
FOR SALE!!
For next term opening departure 輌 purchase, it cries, it cries, you release.
2,700,000 Yen in price
EP91 turbo
At 1999 Tsukuba circuit marking 1 minute 4 seconds 867
Engine itself
4E−FTE base
Forging piston original lightweight [baruburihuta] piston and connecting rod balance taking
Deviation prevention process blow-by gas prevention processing inside oil pan
Turbine air cooled conversion processing
Trust 10 step oil cooler kit
JAM original preface [intakurakitsuto]
Blow off valve less
NGK plug cord
NGK racing 8th plug
The control with JAM original CPU
Turbine
Genuine reforming high flow
Strengthening actuator
[torasutopurohuetsuku] B specifications installation
Exhaust type
JAM original catalyst extension
JAM original TYPE2 muffler
Drive system
Mission itself normal
Only final 4.058
AP racing twin plate clutch
TRD mechanical cable type 1.5WAY LSD
Brake
Front carry per Will Wood 4POT carry per
4POT private brake pad
Rear JAM original type RC brake pad
AP racing adjustment type proportioning valve
APP stain mesh brake line
Suspension bushes
Front
The Cuzco camber adjustment type pyro upper mount
Height pitch for TRD race/lace
Series-wound coming spring 14K for TRD race/lace
Rear
TRD strengthening upper mount
Series-wound coming spring 12K for TRD race/lace
TRD suspension bush
TRD strengthening engine mount
JAM original pyro lateral rod
Interior
[buritsudojigu] you [hurubatsuketoshito]
3 inch [uiranzu] 4Ã?4 seat belts
[kusukokuromoriroruba] 7 point system
Trust 60φ boost gage oil temperature gauge
Crazy shit....it advertised on there site for a good year or so but im unsure if its actually this car that they 5e'd
Also some info on their engine specs when buying one, im guessing there own cars ran similar specs
○ complete engine
[huruhuro] processed forging piston
Piston and connecting rod weight adjusting
Original lightweight [baruburihuta]
Oil deviation prevention processing inside [oirupan]
Turbine air cooled conversion processed thermo- housing
○ price (normal trade-in)
EP91: 280,000 Yen
EP82: 350,000 Yen
○ high cam specification price (normal trade-in)
EP91: 360,000 Yen
EP82: 430,000 Yen
Engine itself EP82
EP91 350.000 Circle
280.000 Circle
Engine removal and re-installation payment 50.000 Circle
Supplemental devices removal and re-installation payments 30.000 Circle
Motor oil BP20W-60 12.000 Circle
Plug NGK racing 9.600 Circle
Coolant Third SCC 2.000 Circle
Oil element 1.000 Circle
When it cannot take in trade the engine, 80.000 Circle
High cam KIT IN EX250°-8.5o lift 80.000 Circle 15.000 Circle
TRD strengthening engine mount set 25.500 Circle
Catalyst extension 38.000 Circle
[buritsutsu] K1-200V turbine 168.000 Circle
Strengthening fuel pump 22.300 Circle
Adjustment type [huyu] - l regulator KIT 22.000 Circle
76.5℃ low temperature thermostat 2.000 Circle
Original computer As for normal trade-in 125.000 Circle
ah it mentions k1-200v turbine... so the high flow ct9 must be running one of blitz's turbine wheels making it it's hybrid variation or it's just running a blitz k1 which would make more sence :lol:
some crazy shiz those japs and some of the parts going in to those engines are mint! wish i had such a spec'd glanza <_<
edit: Also done some digging and according to the Aus site Toby (toytuning) ran a blitz k1 and made '202@ wheels with the pfc f-con, all at 1.3 bar'
so with a bit of a push and the 5e, high lift cams etc 250bhp i think is toatly achievable :blink:
  • 2 months later...
This is fewkin amazing!! i remember watching this vid aaages ago thanks for ressurecting it! its one of them vids where you watch and think I WANT THAT!!! this guy and his brother i think do a series where they boot loads of tuned car down windy jap roads...ne one kno what its called?!
ive found a 5e block and im trying to replicate the jam engine but with the use of a td12, it would be mint to know the lift and duration on the 250ps 5e.
I know nothing about cams but does this mean anything
from the above spec when JAM built customers engines?
yea those are some specs, but those cam specs are pretty mild
with 250 duration and 8.5 mil lift, speedvison is 260 iirc with 8mil lift
id imagine the 250ps glanza had some where between 272 -282 with 8.5 plus lift on inlet and outlet but cant find the magical specs anywere
