Sign in to follow this
Sparky
removing ABS
Right guys, engine is coming out next weekend so while I am at it I want to remove the ABS and all the unnecessary rubbish!!
Now my ABS has never worked and I have Wilwoods waiting to go on so was jut wondering what I needed to buy before I go ripping it all out.
Do I need new brake lines or to blank anything off?
A guide would be good if you could point me to one :)
Thanks Lewis
Share this post
2x T pieces (10x1mm)
8x unions (10x1mm)
copper brake pipe (unsure of sixe as i went braided lines)
brake line flaring tool
right start at the abs pump undo the brake lines that go in it there
then undo the lines off the brake master cylinder,
you should be albe to remove some of the lines from the car now
front brakes!
on the top of the inner wings there a joiner for the brake lines,
undo the brake lines on the side that run to the abs unit,
you will have to make up 2 new lines from the joiner to a T piece ( which can be bolted to the bulkhead)
the make up another line to run from the T piece to the brake master cylinder
on the master cylinder use the hole on the side nearest the windscreen,
rear brakes!
on the bulkhead you should see a bit that looks like this
undo the lines at the top and gently bend them so that you can fit the second T piece like this
then make up a line that runs from the T piece back to the master cylinder
then its a case of bleeding up the brakes and cheak for any leaks
i hope this helps you guys if you are still a bit confused pm me and i try to help as much as i can
Share this post
In this pic, can we take the pump out? and do all 4 of the pipes on the side become redunant?
Also can you show us an invoice of the braided lines so we know what lengths are required
Cheers, great help so far
Share this post
I have a good idea now Si.
Basically you undo the lines that come out of the ABS unit, follow the lines to the junction box on the bulkhead and remove that with the lines.
Replace the juction box with the 2 T-pieces, connect the front lines to the one T-piece and the rear lines to the other, then join the T-pieces with the braided lines to the Master cylinder.
Mark told me you need to measure up the lengths if you want braided lines made up.
I am not sure on the unions though, says we need 8 so I presume 6 go on the end of the T-pieces and the other 2 go on the master cylinder ends?
Share this post
oh good ok mate, if you buy two lots of everything one for you one for me, i'll pay the postage etc
then we can get it all done properly together and see how its done
Cheers
Si
oh who made up the lines for you?
Share this post
My engine should be out this weekend so I'll have a good look and order it all up in the week mate shall let you know
Share this post
awesome bro, I'm needing mine on the road so can't just tinker and take stuff out as I wish in case anythin goes wrong
Share this post
Lew when you get price on all the T pieces etc can you let me know also ? can source lines locally so thats not a problem but if your odering 3 sets may get a little discount ?
Share this post
the pump in the pic can be taking out completely,
i can try and work out the lenghts for you but mine front lines are one piece. they run from the cailper to the T piece,
and sicaln i am working not to far from you next week if your still not 100% sure
Share this post
Ordered the T pieces just dont know what unions to order??? Will be using copper brake pipe if thats any help?
Share this post
justed pm you fella
Share this post
if you get me the length of the lines you need i can make you up custom braided lines in lime green if your interested sparky :p
Share this post
We are using copper brake pipes for now mate but I'll make note of the lengths for future reference :p
Share this post
hey sparky, not had interwebs as I've moved in with the mrs and no Sky yet!
Hows this moving along mate? BenV i'd be interested in blue lines please
Share this post
Hey Si almost done mate, everything is removed apart from the little junction box on the bulkhead which wont take 2 seconds and I have everything now to pipe it back up will try and add a bit more to Marks guide :D
Share this post
Yea mate seeing as we have some readily available, will get measurements for you though bud
Share this post
just a word of warning boys the t section of the origanl system looks to me like a compensater. make sure it is not before removing, needs to be in thr if it is.
Share this post
I'm gonna be doing this hopefully this weekend too - think Sparky finished the job
Share this post
Can u do some more images when youre doing it. Let me know about the lines as well.
Also is that piece a compensator as mentioned by nasty?
Thanks
Share this post
interested to see this done... probably cheaper than sorting the abs out for the mot!!!
Share this post
I have compiled a couple of pics I'll add them here to show the diff in diagramatic form from Toyota, I have the non ABS lines from a Starlet to use
Leeroy, that and weight saving is why I am doing it
Share this post
