Ive been a member on the forum for a lil while now but never got round to putting up any pics and listing my spec so here goes,
16inch Ultralite G-spec alloys in white,
Full setup of KYB Shocks and springs,
HDI front mount intercooler
9mm blitz ht leads,
Polished cooling panel,
HKS actuator,
jap performance d-cat pipe,
HKS high power silent exhaust,
Nomad racing dump valve,
Apexi Boost gauge with apexi pod
Recaro bucket seat JDM style (driver side)
HKS turbo timer
1 off custom built aluminum vent cover for those rainy days
Apexi 1.3bar radiator cap
Forge motorsport aliminium oil catch tank
Zisco performance mild steel ram horn manifold
Air filter relocation kit
HKS Teflon coated braided brake lines
zep racing ecu
Clear cam cover
Ported ct9 x turbo
Walbro 255lph fuel pump
TurboSmart boost controller
De-badged Flushed radio antenna (looks much better)
Zisco rear strut bar
Blitz earthing kit
Im sure i have missed a few things out and im sure there will be a few more to come.
some new bits n bobs!
Loads more to come hopefully ready for summer 2012!!!!
Hello all,
As above i thought i would share some pics,
Any feedback and thoughts welcome!
The block has been bored out to 75mm, new block plugs, Arp crank studs and re-linebored also chemically cleaned and fully tested etc...
The head has been chemilcally cleaned crack, presssure and vacume tested bench and flowed etc with identical combustion across all 4 chambers, valve seats re-cut with cnc and a 1 off direct fit custom head stud kit (not 4a-ge studs as they are not a direct fit) and cruise springs also ported and polished on exhaust side (still awaiting cams and solid buckets)
Pistons rods all Arp connectors, bearings and reground crank fully balanced
Sump and strainer chemically cleaned
Loads more stuff to come will update soon (hopefully ready for summer 2012)
gt35 on a 4e bottom end! Will it spool it!?
NOS is just greedy ;)
Im hoping to use a 25shot of nos just to help the turbo spool up,
will also be using anti lag and launch controll but the big set up will only be for drag days at santa pod
This is awesome matey! Have you been at MFN in it before sure ive seen you down there in it.
Looking forward to seeing some progress dude, looks like it going to be a pretty serious tool.
Cheers,
Sorry mate dont think i have been there but i do go to nottingham now and again
Ive seen the car somewhere before lol!!
did you ever go to hams hall or birmingham cruise i used to go there every weekend and i did attend a meet in brum a few months ago at star city which was organised on here but only 3-4 other cars turned up so i left after about 30 mins.
  • 6 years later...
I got rid of the zep ecu ages ago. Engine will be ran in with the stock ecu on td04 hybrid before i get a standalone. Not chasing silly power anymore. Drivability and a wide powerband is the aim
  • 3 months later...
Small update got my oil and water lines back i got these made locally for £70.
Freshly rebuilt turbo (rebuilt by Midland turbo)
Twin core full size zep racing rad from rhdjapan.
The car is 95% complete hopefully it fires up this saturday for the first time in almost 30 months.
