Fifress Posted March 6, 2016 Share Posted March 6, 2016 Any chance the ep91 wiring is same as the ep82 mk2 cluster (also 3 connectors)? I have a mk1 cluster 2 plugs and a mk2 loom 3 plugs... Quote Link to post Share on other sites
Jason1993 Posted June 1, 2016 Share Posted June 1, 2016 Seen a few people getting confused about the 98 spec n/a wiring being different.. I tried this yesterday on mine and the wiring is different to the 96 spec.But the SR clocks are a straight 'plug and play' into 98 wiring!! I had the wires from the SR to match up and they are all exact same and everything works fine for me. Thought I'd clear it up for a few people Quote Link to post Share on other sites
Jack cotti Posted August 7, 2016 Share Posted August 7, 2016 Anyone know if the this is the same for the cd clocks to a sportif Quote Link to post Share on other sites
MR-2 Posted August 8, 2016 Share Posted August 8, 2016 Gona try lhd 1996 EL54 Paseo cluster swap to lhd 1996 EP91 Starlet. A and B connectors seems to be same as uk model, C is different. Very good info here you guys, only missing written wire colors, order is same in many case, but colors are not same. RPM signal is black/blue in Paseo wiring by the way. Does Your area Starlets have low fuel sender in tank, only thing that I'm missing now, should I try connect it also, Starlet gauge don't have bulb for that. Same age Corollas have it in tank pump hanger?Sorry, finnis language pin preparation, no use for english readers Gona write better with computer later... Quote Link to post Share on other sites
MR-2 Posted August 8, 2016 Share Posted August 8, 2016 Working, what a job to solve every wire. Only door open light didn't work, have to solve it later at daylight. And drive with gps, maybe speed needle needs calibration, same scale but topspeed raised 180km/h to 200km/h. Quote Link to post Share on other sites
MR-2 Posted August 9, 2016 Share Posted August 9, 2016 Today I I tried to install paseo clocks and I failed :/ rpms doesn't work.In my case EP91 Starlet A6 black is rpm signal and needed to swap A10 (black/blue) in EL54 Paseo cluster. Quote Link to post Share on other sites
Jamesreeveep91 Posted October 30, 2016 Share Posted October 30, 2016 Is this the same a changing to glanza clocks? Quote Link to post Share on other sites
Jamesreeveep91 Posted October 31, 2016 Share Posted October 31, 2016 Is this the same as changing to glanza v clocks? Quote Link to post Share on other sites
fiddlersport Posted November 1, 2016 Share Posted November 1, 2016 Easy to remove speedo connector off gearbox then clocks just push out easy for cable removal Quote Link to post Share on other sites
Ruddock111 Posted August 16, 2017 Share Posted August 16, 2017 Looking to put white paseo dials in the 96 starlet sportif but wondering which wire do I use for tacho pulse. As previously mentioned A6 on starlet to A10 on paseo, but according to the wiring diagram (starlet), there is no A6. Quote Link to post Share on other sites
Allyboy81 Posted August 23, 2017 Share Posted August 23, 2017 Hello lads, I'm after a bit of help please. I'm trying to fit a starlet cd model speedo head/clock to my solida! I was told cd model should be plug and play!! But it ain't. From what I seen when it was plugged in I had oil pressure light on constant no rev counter no eml and no full beam warning light. I have looked over the how to guide and the wiring in the guide looks different from mine. I can't seem to upload photos either but if anyone has any info in the mean time let me know thanks Quote Link to post Share on other sites
The Trooper 1815 Posted August 24, 2017 Share Posted August 24, 2017 (edited) I have a UK S reg 1.3 NA. It does not have an RPM gauge, just speedo, temp and fuel.What other clocks fit without chopping any cables?Thanks Edited August 24, 2017 by The Trooper 1815 Quote Link to post Share on other sites
Allyboy81 Posted August 25, 2017 Share Posted August 25, 2017 I just finished fitting my cd clocks! All went well not as bad as thought had to lengthen a few wires but the rest was swapping pins about. Great guide from tommy_g http://i89.photobucket.com/albums/k222/Tommygerrett/Finallookofplugs.jpg Quote Link to post Share on other sites
Fin86 Posted January 21, 2018 Share Posted January 21, 2018 Hi am new to da site.. help needed Ive a 99 starlet xli wit no rev counter i bought glanza s clocks but rev counter dont work an indicator lights stay on an no backround lights work any help folks Quote Link to post Share on other sites
l i am Posted April 15, 2020 Share Posted April 15, 2020 On 8/16/2017 at 5:28 PM, Ruddock111 said: Looking to put white paseo dials in the 96 starlet sportif but wondering which wire do I use for tacho pulse. As previously mentioned A6 on starlet to A10 on paseo, but according to the wiring diagram (starlet), there is no A6. hi mate did u manage to get the paseo clocks all working in your sportif? Quote Link to post Share on other sites
l i am Posted April 15, 2020 Share Posted April 15, 2020 i followed this guide and put CD clocks in to get rev gauge from sportif and all good now i have a set of paseo clocks and wanting to change but abit confued as to the wiring. has anyone actually got paseo clocks in a sportif? thanks Quote Link to post Share on other sites
Sam44 Posted April 16, 2020 Share Posted April 16, 2020 Thanks for finding this I've got a set of paseo clocks to go in also. I have a cd model. Quote Link to post Share on other sites
