Xpect Posted February 23, 2014 Share Posted February 23, 2014 As in Topic, what are the differencies between the NA and Turbo engines? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted February 24, 2014 Share Posted February 24, 2014 The N/A ignition system has the coil built in to the distributor so does not have the external one like the turbo engines. The turbo engines have the distributor and a coil pack. Quote Link to post Share on other sites
Xpect Posted February 24, 2014 Author Share Posted February 24, 2014 Is the NA ignition capable of running a boosted engine? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted February 24, 2014 Share Posted February 24, 2014 Yes it is mate had a boosted 4efe using the n/a ignition system and had no problems, my current engine was going to use the same set up but ended up going coil on plug as Im using a stand alone ecu. Quote Link to post Share on other sites
Xpect Posted February 25, 2014 Author Share Posted February 25, 2014 Thanks. Another piece of info gathered. Quote Link to post Share on other sites
rwdrev Posted February 25, 2014 Share Posted February 25, 2014 rob, i have seen your set up and looks really smart, was it easy enough to make and what parts did you source from what cars? Quote Link to post Share on other sites
