Azz Posted July 10, 2014 Share Posted July 10, 2014 http://www.driveshaftshop.com/These can make any drive shaft Quote Link to post Share on other sites
morgey Posted July 10, 2014 Share Posted July 10, 2014 No fucks given drag build ftw! Quote Link to post Share on other sites
Jamie5414 Posted July 10, 2014 Share Posted July 10, 2014 holy fuck lol...impressive Quote Link to post Share on other sites
andros starlet Posted July 11, 2014 Author Share Posted July 11, 2014 (edited) some extra pics Edited July 11, 2014 by andros starlet Quote Link to post Share on other sites
shorty Posted July 12, 2014 Share Posted July 12, 2014 Mental! Looks savage mate. Bear in mind tok its the same size shaft as an ae86 on most ep85's so worth doing some measurements there as you can use ae86 shafts and they are already available from some places. Also the kouki ae86 rear diff works too. Quote Link to post Share on other sites
andros starlet Posted July 13, 2014 Author Share Posted July 13, 2014 Mental! Looks savage mate. Bear in mind tok its the same size shaft as an ae86 on most ep85's so worth doing some measurements there as you can use ae86 shafts and they are already available from some places. Also the kouki ae86 rear diff works too.i can't use the kouki dif because it is too weak for my car ... and as for the ae 86 shafts there are much different ,it can't be done . i need a rear end complete stronger with the same ratio 2.2 from another toyota ... Quote Link to post Share on other sites
andros starlet Posted July 14, 2014 Author Share Posted July 14, 2014 (edited) this is some footage from the last dragster Edited July 14, 2014 by andros starlet Quote Link to post Share on other sites
shorty Posted July 14, 2014 Share Posted July 14, 2014 Ok my bad i got my ae86's confused. Direct quote from uksc and the legend of starlets that is Enzo (dont care what anyone thinks he knew/knows his shit!)"rear axle sizes are 24 mm which is the same as the zenki (early shape) ae86 corollaso any lsd for that rear diff fits into this diff cusco and kazz make lsds for thisalso if you are aimng for big power I've also found a company that makes custom rear strengthened axlesas ths is onsidered the weakest point in the 4paws setup 24m is awfull thinsome eye candy!http://www.weirperformance.com/axlekitscompleterear.html "I really hope he doesnt mind me sharing this but 4wd info is rare and few and far between tbh. Quote Link to post Share on other sites
daniel_g Posted July 14, 2014 Share Posted July 14, 2014 Always good to hear more 4paw info !! Never knew the early AE86 diffs fit !! Quote Link to post Share on other sites
andros starlet Posted July 14, 2014 Author Share Posted July 14, 2014 (edited) Ok my bad i got my ae86's confused. Direct quote from uksc and the legend of starlets that is Enzo (dont care what anyone thinks he knew/knows his shit!) "rear axle sizes are 24 mm which is the same as the zenki (early shape) ae86 corolla so any lsd for that rear diff fits into this diff cusco and kazz make lsds for this also if you are aimng for big power I've also found a company that makes custom rear strengthened axles as ths is onsidered the weakest point in the 4paws setup 24m is awfull thin some eye candy! http://www.weirperformance.com/axlekitscompleterear.html " I really hope he doesnt mind me sharing this but 4wd info is rare and few and far between tbh. i have already test an ae86 shaft and they can't match ... Edited July 14, 2014 by andros starlet Quote Link to post Share on other sites
shorty Posted July 15, 2014 Share Posted July 15, 2014 Lol you miss the point that company does custom shafts. Have you emailed them? Or shall i do more work for you? I dont really know what your after mate? You asked where to get them I've given you the info. If you cant work out from here then best get a different car lol. Quote Link to post Share on other sites
andros starlet Posted July 15, 2014 Author Share Posted July 15, 2014 Lol you miss the point that company does custom shafts. Have you emailed them? Or shall i do more work for you? I dont really know what your after mate? You asked where to get them I've given you the info. If you cant work out from here then best get a different car lol.i am sorry if i put you in trouble , i asked if there is any shop that has racing shafts for ep 85 because if i go custom is too expensive , i emailed some shops in uk and the price was about 1500 eu without even the bearings !!! some told me i can fit racing shafts of an ae86 but this is impossible ... and i can't even fit the ae86 diff because of the ratio ( it's different ) and i won't get a different car because i love starlets . any advice is appreciated ... Quote Link to post Share on other sites
morgey Posted July 15, 2014 Share Posted July 15, 2014 Youre going to have to change something.The final drive is the ring gear which is removable from the diff right?, can this not be made to fit the ae86 diff then What about running 86 hubs so the bearing then also fit. Or what about finding another rear axle from another car that runs the same FD as the starlet and make that fit instead? Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 (edited) Youre going to have to change something.The final drive is the ring gear which is removable from the diff right?, can this not be made to fit the ae86 diff then What about running 86 hubs so the bearing then also fit.Or what about finding another rear axle from another car that runs the same FD as the starlet and make that fit instead? a couple days ago i understand the easy way is another diff stronger from another toyota ,but the main issue is the same ratio , i need 2.2 ratio ! i google toyota diffs 2.2 ratio but no luck ... i hope i will find a solution soon because in a few months coming the next dragsters Edited July 16, 2014 by andros starlet Quote Link to post Share on other sites
weeman Posted July 16, 2014 Share Posted July 16, 2014 I dont suppose you do much corning but how does it feel with the welded diff? Definatley looking down this route to as im sure it wont last to long with big launches and I want to go faster!Anyone know what the quickest 4wd 1/4 mile is in a starlet? Quote Link to post Share on other sites
shorty Posted July 16, 2014 Share Posted July 16, 2014 Contact the site in the quote I've put up. They do custom forged shafts from $210 thats really not alot atal. No one has off the shelf parts for an ep85. Its the joy of rare cars. The japs didnt really mod them either so there are no jap performance parts for them. Clearly they knew something we didnt. Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 (edited) I dont suppose you do much corning but how does it feel with the welded diff? Definatley looking down this route to as im sure it wont last to long with big launches and I want to go faster! Anyone know what the quickest 4wd 1/4 mile is in a starlet? i did 2 things , one was i weld the diff , not too much trouble there but when i remove the viscous o my god :)i can't turn too much the steering wheel i did 9.1 flat in 300 meters not 402 because the drag line is 300 meter . not enough motorsport in cyprus to built a regular dragline !!! i hope some day they do Edited July 16, 2014 by andros starlet Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 Contact the site in the quote I've put up. They do custom forged shafts from $210 thats really not alot atal. No one has off the shelf parts for an ep85. Its the joy of rare cars. The japs didnt really mod them either so there are no jap performance parts for them. Clearly they knew something we didnt. great i will email them right now , thanks !!! Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 (edited) . Edited July 16, 2014 by andros starlet Quote Link to post Share on other sites
daniel_g Posted July 16, 2014 Share Posted July 16, 2014 How much power do you have in the 85, and what kinda turbo is that ? Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 How much power do you have in the 85, and what kinda turbo is that ?don't know the power , no dyno yet , but its from an evo 9 and boosted more than 2.5 bar plus 100 hp wet nos Quote Link to post Share on other sites
daniel_g Posted July 16, 2014 Share Posted July 16, 2014 Need to get that on a dyno buddy, must be kicking out some power !! Quote Link to post Share on other sites
andros starlet Posted July 16, 2014 Author Share Posted July 16, 2014 you won't believe if you drive it ... Quote Link to post Share on other sites
daniel_g Posted July 16, 2014 Share Posted July 16, 2014 you won't believe if you drive it ...They are great cars to drive even with low power, so yeah i could imagine how fast this must be haha Quote Link to post Share on other sites
