Stange oil leak cam cover side
Hey guys, was doing a few odd jobs on the car yesterday and noticed i have an oil leak! quiet a few drops of oil on the floor after parked up for 10 mins so its something i need to look at.
From underneath its dripping from the car cover side of the sump right under the crank.
From above there looks to be oil getting flicked up onto the side of the cam over and even little bits on the rocker cover, i think it may be getting on the belt too as it squeeled when i drove it this morning...
im guessing crank seal but i wanted to get your opinions on what it may be? any common leaks etc?
any advice or info is appreciated!
Cheers
Josh
i have recently resealed up my cam over as that was leaking on the other side last time so i dout it is but over the weekend ill whip off the cam over and maybe even the aux belts and have a proper look
if it is the crank seal, is it a large job to do?
Not 100% sure on this one guess you have to take the cam out and replace seal cant see it being a massive job
If I was in this position mate I would get some brake cleaner so every part of the oil is off and the engine where oil was is clean etc then turn engine on and leave it on ideal and try locate where the leak is coming from 👍
