Toyota Starlet GT Turbo Ep82 MK2
Toyota Starlet Gt turbo Ep82
For sale is my beloved Gt turbo, I've only had the car a month or so but I can tell you it's the funnest thing I've ever driven. I am reluctant to sell but situations have changed and I am forced to get rid for a few reasons one being financial.
It was first imported back in 2005; the car itself is a late 1992 model and is the second generation (mk2) ep82.
It has MOT till 25/03/2015 and tax till 01/12/2014.
The car has covered a little bit over 98600 but this is a mixture of km and miles.
The Car body wise is not the best, but don't let that put it down, the paint work is gorgeous when it's polished up and really does shine. There is some lacquer peel on the roof which is common with this generation and colour, and there also various cracks in the lacquer but never bothered me. The front bumper is faded, and the sides do have some marks and dings but nothing major.
The car engine wise is fairly standard, the only modifications being a
genuine baileys dump valve
5zigen cat back exhaust
Magnekor HT leads H
KS mushroom airfilter.
This allows for the potential of some major power increases and modifications, I was told by previous owner it was running about 145-150 with these mods on high boost, which is a fair estimate and in a car that weighs well under a tonne, that's more than enough. It comes with the optional factory LSD also.
Now since my ownership I have replaced the radiator and thermostat for oem replacements, this was because it was overheating when boosting hard. We have now identified the problem and it is the water pump. It still works and runs fine, boosts well it just leaks and causes it to overheat. Now a brand new oe replacement is £30 and fitting I have been quote £30-£50 by a friend so really isn't expensive. I would keep the car and fix it but as aforementioned, situations have changed which lead me to sell it.
Interior wise it is fairly standard also, there is a boost gauge fitted by a former owner which oddly is on the passenger side but can still be seen, it also has a momo champion steering wheel fitted . It does come with a stereo however it isn't fitted and will need a harness to do so. It also comes with optional extra air con (needs re-gassing) and optional extra wind deflectors. All electrics work bar the interior light and the digital clock.
It comes on a set of 15" momo racer wheels, the front 2 tyres are not far off legal limit on inside edge. Suspension wise it has tein coilovers on the front (HA I believe) with camber and rebound adjustment, on the rear just some 40mm springs on shocks, It's recently had new cv and ball joints iirc and front discs.
I really do not want to sell up but needs must, I have put it up for £1500 taking into consideration the repair that it requires, I am open to close offers and even swaps for a car and cash my way. I'd be looking for some sort of old civic at a push EK shape, but preferably older, another starlet preferably EP91 NA or another small nippy hatchback.
Viewings and/or questions are welcome, texts preferred due to working hours and such like.
Sam on 07402950069
Car is located in Carlton NG4
10559065_10152304322943845_1650957318_n_
10564653_10152304324238845_2138799431_n_
10555162_10152304322528845_771863701_n_z
10663152_917338981615091_991709788_o_zps
10566285_10152304322658845_2035782726_n_
10510132_10152304324168845_1233719759_n_
10543277_10152304322173845_1666332644_n_
10543135_10152304322623845_743114452_n-C
