  • 2 months later...
  • Replies 760
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
so general update, been dyno'd at 167hp and 121lb ft, so very happy that the engines healthy.
dyno video's
first power run
http://youtu.be/cjhcV21u3Zw
2nd run
http://youtu.be/B1hmDie16LI
not sure which this was but 1080p greatness :)
http://youtu.be/uYkwmNPLzJk
dyno was done at clive atthow in norwich on a dasket 1500hp dyno, should be fairly accurate as a friend got his FD2 civic type R dyno'd which should make 222hp stock and it made 223hp so it was a nice comparison so have.
acceleration vid.
http://s123.photobucket.com/albums/o310/mo...nt=MOV00129.mp4
I've posted these up in the video section but thought they may aswel be in here also as its where their from
  • 2 months later...
as by my usual standard of slackness, i have finally got round to uploading my dyno graphs so here they are finally
and not sure if this one will work as i stole it from facebook but here's 2 of the latest additions to the engine bay...
75mm trumpets with itg filter which sound AMAZING ;) (fitted after dyno)
and a TRD upper strut brace which could do with a bit of a refurb but its not that bad tbh.
truth be told the intake sounds so good im getting the exhuast made quieter so i can hear it better :)
hmmm dont tempt me :)
anyway i havnt finished with it yet, lsd, cam's, trd headgasket and an ecu are on the wishlist + sorting out the stance a lil bit as the rear wheels are lost haha
but if your generally interested i can always hit you up when i do think to sell it!
Yeah I see what he means but if you were to use the the same figures as the power line uses then it prob would or be close too, but for what ever reason (prob to make it clearer) they used two separate sets of figures which means it doesnt as it spreads it out alot more
Either way my peak torque is nearly 1k rpm higher than the stated stock specs.
  • 2 months later...
