Headgasket advice
Headgasket needs doing on the Glanza. Currently runs 1bar td04 on standard engine.
Will probably do some headwork and get bigger injectors and maybe go to 1.2bar
What sort of headgasket should I get, what does anyone recommend?
Thanks
As far as I know this will be the first time the head has been off so everything should be as standard.
Whats standard thickness gasket and what advantage is there to changing that, I know it changes compression but how does that affect things like lag or just how the engine performs?
Edited by Galen
