Duduglanza Posted February 1, 2016 Share Posted February 1, 2016 Has anyone here managed to swap gbox from another toyota car? Im tired of rebuilding mine and changing syncros every now and then to have decent gearshifting Quote Link to post Share on other sites
5e colin Posted February 1, 2016 Share Posted February 1, 2016 socks done a mr2 turbo box on his 2zzge in the starlet with custom shafts pm him its not a simple job Quote Link to post Share on other sites
Duduglanza Posted February 1, 2016 Author Share Posted February 1, 2016 I was told that mr2 / celicas gbox are done but i have never seen on. Quote Link to post Share on other sites
5e colin Posted February 1, 2016 Share Posted February 1, 2016 ya its not simple needs adaptor plate between box and engine etc etc Quote Link to post Share on other sites
Duduglanza Posted February 1, 2016 Author Share Posted February 1, 2016 I know its not simple. Just need to confirm Quote Link to post Share on other sites
funny onion Posted February 1, 2016 Share Posted February 1, 2016 (edited) I have a G6 6 speed corolla gearbox in one of my GT's Edited February 1, 2016 by funny onion Quote Link to post Share on other sites
Stu Posted February 1, 2016 Share Posted February 1, 2016 (edited) C56 is a common conversion, shorter final drive and a few different gear ratios. Same design internally. Just swap off the 4age bellhousing and drill the passenger side mounts into the casing and your good to go. Good and strong. C160 also fit but are a weaker box. Probably fine for most setups though. Larger E series boxes don't physically fit without massaging the chassis Edited February 1, 2016 by Stu Quote Link to post Share on other sites
Duduglanza Posted February 2, 2016 Author Share Posted February 2, 2016 I have a G6 6 speed corolla gearbox in one of my GT'sDo 2nd gear crunch? Quote Link to post Share on other sites
funny onion Posted February 2, 2016 Share Posted February 2, 2016 Do 2nd gear crunch? No everything is fine no crunches, the shorter ratios give it more of a punch in the lower gears than a starlet box. only thing you have to modify is the shifter as reverse is next to first on this box. just need to notch some plastic from the shifter housing. gear cables, mounts etc are a straight swap Quote Link to post Share on other sites
Phil Posted February 2, 2016 Share Posted February 2, 2016 C56 is a common conversion, shorter final drive and a few different gear ratios. Same design internally. Just swap off the 4age bellhousing and drill the passenger side mounts into the casing and your good to go. Good and strong. C160 also fit but are a weaker box. Probably fine for most setups though. Larger E series boxes don't physically fit without massaging the chassisWhat's the strongest box availible ?C52?Phil Quote Link to post Share on other sites
Stu Posted February 2, 2016 Share Posted February 2, 2016 Stock c52 and c56 are very similar other than the c56 is a shorter ratio box. Both are pretty strong. C150 (EP71 N/A), C152 (EP71 Turbo), C160 etc are all lighter weight gearboxes Quote Link to post Share on other sites
Bananajoe888 Posted February 3, 2016 Share Posted February 3, 2016 Will a C64 Gearbox fit? Does it hold enough power?E58 would be perfect!!! Quote Link to post Share on other sites
Phil Posted February 3, 2016 Share Posted February 3, 2016 Will a C64 Gearbox fit? Does it hold enough power?E58 would be perfect!!!Not sure what all would need done to make a c64 fit but Juba do an uprated 3rd/4th gear for them so def a swap I'd be interested in.Come in Toyota engines lotus etcPhilWhat's the craic with an e85?Phil Quote Link to post Share on other sites
Bananajoe888 Posted February 3, 2016 Share Posted February 3, 2016 (edited) E58 can hold tons of Newtonmeter Torgue =Dbit heavier.. but i think u cant break it with a starletdoes somebody now how Strong the C64 gears are compared to C52? Edited February 3, 2016 by Bananajoe888 Quote Link to post Share on other sites
Stu Posted February 3, 2016 Share Posted February 3, 2016 E series boxes are physically much larger, you need to do some "manipulation" to make them fit. Plus they dont come with an e series bellhousing Quote Link to post Share on other sites
Bananajoe888 Posted February 3, 2016 Share Posted February 3, 2016 E series boxes are physically much larger, you need to do some "manipulation" to make them fit. Plus they dont come with an e series bellhousingyea thats shit.... cant someone make a custom bell housing?or where i can get a e58?? Quote Link to post Share on other sites
Phil Posted February 3, 2016 Share Posted February 3, 2016 E58 can hold tons of Newtonmeter Torgue =Dbit heavier.. but i think u cant break it with a starletdoes somebody now how Strong the C64 gears are compared to C52?No way of getting e85 gearset into our casing/bell housing?Phil Quote Link to post Share on other sites
Stu Posted February 3, 2016 Share Posted February 3, 2016 Nope, totally different, phyiscially huge by comparison Quote Link to post Share on other sites
Phil Posted February 3, 2016 Share Posted February 3, 2016 Nope, totally different, phyiscially huge by comparisonBummer Quote Link to post Share on other sites
Bananajoe888 Posted February 4, 2016 Share Posted February 4, 2016 No way of getting e85 gearset into our casing/bell housing?Phil NO sry, no chance to do thati think i try C64 swap in my starlet. Think this will hold better than C52..300whp is much.. Quote Link to post Share on other sites
Phil Posted February 4, 2016 Share Posted February 4, 2016 NO sry, no chance to do thati think i try C64 swap in my starlet. Think this will hold better than C52..300whp is much..Fire us as many details as u can I wondered before if a c64 gearset would fit in one of the 6speed gearboxes that people use from a g6 corrolla? Then mate it to the c52/56 bellhousing? Pretty sure the c64 casing isn't suitable in terms of selector position and starter position etc being from a rear engines rwd lotus What gearbox comes in a fwd tsport 2zz?Phil Quote Link to post Share on other sites
morgey Posted February 4, 2016 Share Posted February 4, 2016 Same box, the corolla and celica use C64 and 63 i think. The celica has closer ratios in 2nd and 3rd i believe.The boxes can be modified to it front or rear engined like the old c52 in the old aw11 mr2 Quote Link to post Share on other sites
5e colin Posted February 4, 2016 Share Posted February 4, 2016 NO sry, no chance to do thati think i try C64 swap in my starlet. Think this will hold better than C52..300whp is much.. if the driveshafts inner cups from starlet fit then your onto a winner Quote Link to post Share on other sites
Bananajoe888 Posted February 4, 2016 Share Posted February 4, 2016 Guys.. had a interesting talk with an Motorsport guy from Germany... he told me a way to use C64 (Corolla T-sport gearbox) nearly PnP on starlet. he said "you only have to combine the right parts =P Quote Link to post Share on other sites
Stu Posted February 4, 2016 Share Posted February 4, 2016 (edited) Its just a case of using the right housings so that the gearbox bolts to a e series engine. EDIT: Its interesting looking a the ratio comparisons between the C56 and the C64. C56A 5-Speed Manual Transmission for FWD and mid-engine cars. Compared to the C50/52, it features close-ratio 3rd-to-4th gearing.1st 2nd 3rd 4th 5th Reverse Final3.166 1.904 1.392 1.031 0.815 3.250 4.312C64 1st 2nd 3rd 4th 5th 6th Reverse Final3.166 2.050 1.481 1.166 0.916 0.815 3.250 4.529 Really short final drive, would be doing a fair few revs at 100kph! Edited February 4, 2016 by Stu Quote Link to post Share on other sites
