Will4glanzav Posted February 8, 2016 Share Posted February 8, 2016 Hi AllNeed bit of help Im swapping my n/a front brakes for glanza v ones an bought the calipers an carriers from jdm-ep ive done my measurements should be straight swap k lol ... but only thing unsure on is discs an pads i see sizes from 254-256mm an loads of different pads shapes any advise? Or links?Much appreciatedWill Quote Link to post Share on other sites
Keri-WMS Posted February 9, 2016 Share Posted February 9, 2016 Hi Will, I'm based in Hastings / Bexhill if you wanted WMS 110% discs and/or DS2500 pads? If so, if you bring your calipers over I've got EP91 hubs so we should be able to do a dummy build to check you've got the right pads/discs before you start faffing with your car? Just a thought! Quote Link to post Share on other sites
