Sign in to follow this
ChrisLeeBoost
Service manual?
Anyone have any links to an online service manual for ep91 turbo.. Need tourque settings for head bolts and general head gasket replacement info! Cheers lads :)
Share this post
Yes mate but let's just see what others post first to be on the safe side here, don't forget to do it in the right sequence, NOT tightened them 1-10
Share this post
cheers mate I'm dreading the thoughts of doing the head gasket it seems daunting to say the least! Just the timing is confusing me a tad
Share this post
Yeah I know what you mean mate, there are guides about though to help you through 👍🏻
Share this post
you can get the hayes manual for the rolla 4efe al torques are in there
make sure the threads are clean
torque to 22nm ( untill the wrench clicks
then 44
now you use tipex and mark every bolt at 12 oclock now you can ad your 1/4 turn to them and look at the headbolts if there facing passo side
Share this post
Thanks a lot lads appreciate the help! Will pull head off the weekend! Will it 100% have to be skimmed? Just to be safe like?
Share this post
Create an account
Register a new account
Sign in
Sign In Now
