Silver SR restoracing project
  • Replies 239
Posted Images
  • 3 weeks later...
I gave the box a small clean whilst it was out and fitted a new aisin clutch, old one didn’t look too worn even though the pedal felt high but the release bearing was a bit buggered so glad that’s been done1339A7CE-8530-42CB-86B0-F66760BA6222.thumb.jpeg.9e1cc334785845e0307dae209b67bb81.jpegA40F28B4-1E8B-438B-8AAC-94F1CE2A5C5E.thumb.jpeg.d2a63f04cc0435a6bccaecc9aadb6042.jpeg4F953331-B9B5-4AEE-A32B-50EA54CD3D54.thumb.jpeg.b3f75dbe54271b3282721dbbd45373d9.jpegAFE70305-7D44-4FE5-A306-408DFFC54CEE.thumb.jpeg.d91c08cfccd1d168417cc2a09d9d1715.jpegFBE94567-1C82-4372-AC7B-751F5BD5C89B.thumb.jpeg.08571279bc2cd13e4eee458fc8425283.jpegbefore33ADC37D-11A9-4623-B601-5E43EFED90D2.thumb.jpeg.f6049412920c32e470d93ff00835cc30.jpegafterFBED172E-B110-4B55-AA3D-900BFC018896.thumb.jpeg.091639a0182941231de7136ee4adf9f5.jpeg
12 hours ago, stevie82 said:
It’s just a mock up, it will be bolted with eyelets through the floor with support plates :)
bolting it down to the floor is not a good idea either, in a crash it will rip through the seat and crush you down. You need to add a bar behind the seat at shoulder height
It’s for time attack, what I’m using is perfectly safe and if the plate I’m using rips through the floor it would be the least of my problems. ideally I would mount it to a cage but it’s not having one and doesn’t need one to compete in the class it will be running in but thanks for the concern
  • 3 weeks later...
let s know how the dyno goes as im keen to see if the corolla mani makes a difference.  If you can get hold of the support bracket then I would as the mani will crack eventually. If you cant find one then I have one that I made until I managed to get hold of a proper one
  • 4 months later...
Not been on for a while and work on the sr has slowed a little but it will definitely be ready for this years tss. I’ve decided to change the bonnet and drivers wing due to damage from previous owners and change the bumpers as I don’t like the smoothed ones that are on it now
I knew the car had been involved in a rear end shunt at some point of its life as I noticed the boot floor was creased when I went to view the car so was prepared to fix it properly..... even though the back panel was £240 from Toyota 😱 196EC199-A0D6-43F6-B4F4-0979AC590015.thumb.jpeg.7e1035a09501bd4f40f42fcb08e304eb.jpegF7D2D3BC-42D0-4637-BE45-452879F8B644.thumb.jpeg.08dec70fa5b742d96bf81ab84cfb2941.jpeg7C9C2EDB-6DB5-4CEC-8DDF-3DC6F284BA53.thumb.jpeg.f8490dba6b7e5de96b6f4362cfa368fd.jpeg
