glanzalee123 Posted April 29, 2016 Share Posted April 29, 2016 Year:1996Model:Toyota starlet glanza vTax:N/AMot:31st July 2016Millage:140000EngineTuning developments stage 2 fully forged engineWossner 74.5mm Low Compression Piston Kit with Rings and PinsScat 4EFTE Forged Conrod Kit with ARP Rod BoltsAthena 1.2mm Uprated Metal HeadgasketARP 2000 Uprated Headbolt Kit inc New WashersGenuine Toyota Full Gasket KitGenuine Toyota Oil Pump KitOEM Water Pump KitOEM Cambelt Kit inc Idler & TensionerACL Main Bearing KitACL Big End Bearing KitACL Thrust Washer KitFully Machined and Polished 4EFTE Bottom EndFully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard SpecBlock, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver Theme460cc InjectorsJ performance FMICWEPR external wastegated manifold/decat and screamer pipeTial external wastegateRecon TD TDO4 turborace tech water lines & TD oil lineTD low temp thermostatMagnecore HT leadsdean RW developments battery clamp & oil captwin core civic radiator with fan- toyota coolantsard FPR with gaugehalfords batterymagnetic sump plugdean RW developments full custom cat back exhaust system with a unreel angle back boxID workz heat slam pannelTD fuel pumpPurple and blue hosing i.e radiator pipes/power steering pipesTD brake and power steering coverspowerflex engine mountNGK heat range 7 spark plugsOEM fuel filterOEM dizzy cap and rotor armpcvDrivetrainBran new spec stage 3 paddle clutchOem LSD gearbox ChasisBC racing coiloversEBC grooved discs and yellow padsOEM front and rear 3 point braceC pillar bar bracehells braided brake lines all aroundOEM x2 hand brake cables15 rota grid Vs with parada spec 2 tyres 195/50/15FULL hunter alignment InteriorOEM fishnet recaro interior- rear seats/door cards/front seats OMP style steering wheelsound proofing insideEMB ECU kitBlitz dual boost controller Exterior Genuine JAM front lip/99 spec bumper & grille- fresh paintOEM rear lip/bumper-fresh paintOEM duck tail spoilerID workz live sports spoiler-fresh paintscuttle panel- fresh paintOEM side skirtsOEM bonnet99 Spec facelift rear lightsNEW OEM toyota glanza headlightstilted number plate bracket/ X2 new number plates8000k HIDS hi/lowcivic rad has custom brackets made up not cable tiePrice : £6000 OnoContact: Either pm on here or 07783268586 Link to post Share on other sites
Hawwy Posted May 17, 2016 Share Posted May 17, 2016 Is this still for sale Link to post Share on other sites
Adam M Posted May 31, 2016 Share Posted May 31, 2016 +1 still for sale? Link to post Share on other sites
jimmymac101 Posted June 1, 2016 Share Posted June 1, 2016 Swap for a 2008 impreza rx? ( non Turbo ) Link to post Share on other sites
SpenceGT Posted March 30, 2017 Share Posted March 30, 2017 Who bought this BEAUTY Link to post Share on other sites
jimmymac101 Posted March 30, 2017 Share Posted March 30, 2017 I think he kept it in the end:) James Link to post Share on other sites
